Power break question
Old Aug 16, 2009 | 07:35 AM
7278ford's Avatar
7278ford
I just power breaks onto my 72' F100. The booster is from a 79 F150. When I hit the brakes, I can here the booster sucking air in through the cab. Is there supposed to be some sort of filter or dust cap to quiet this down?
Old Aug 16, 2009 | 07:19 PM
mcdobson's Avatar
mcdobson
You should not hear any sucking of air. That is vacuum being sucked through the diaphragm of your booster. That is the "broken" diaphragm of your booster.
New booster. Sorry.
Old Aug 18, 2009 | 07:13 PM
7278ford's Avatar
7278ford
I only hear it when I press down the pedal. Once the pedal is down I don't hear it anymore so I don't think it is the diaphram being bad, because I have good pedal feel and power assist. But I could be wrong.
Old Aug 18, 2009 | 07:23 PM
70_RangerXLT's Avatar
70_RangerXLT
99% sure it's a bad booster.
You shouldn't hear any vacuum at any time when you depress the brake pedal.
Actually, even with a bad booster, you shouldn't hear it sucking from inside the cab if you put the dust boot on right, because a booster from a 79 should be mounted remotely on brackets and it has a bellcrank mechanism to activate it.
Old Aug 18, 2009 | 08:50 PM
7278ford's Avatar
7278ford
That's what I am wondering is about the dust boot. All I had with the booster and the master cylinder is a black plastic tube that went from the boster to inside the cab. I am thinking that there is supposed to be another piece there.
Old Aug 18, 2009 | 09:20 PM
70_RangerXLT
If you have a plastic tube, it's not from a 79.
That was only used through 72, if my memory serves me correctly.
Does the push rod go straight from the pedal into the booster?
Old Aug 19, 2009 | 04:54 AM
7278ford's Avatar
7278ford
Yes it does and the plastic tube goes around the push rod.
Old Aug 19, 2009 | 05:31 AM
70_RangerXLT
You've definitely got a bad booster.
Old Aug 19, 2009 | 05:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What plastic tube routes from the brake booster to inside the cab?
What would be its purpose?
I've never seen or heard of any such thing. There's nothing like this shown in the parts catalog illustrations either.
The only plastic piece on the rod (at the end) from the booster to the brake pedal...is a bushing used in conjunction with the pedal mounted brake (stop) light switch.
Old Aug 19, 2009 | 05:44 AM
ford390gashog's Avatar
ford390gashog
The only plastic piece on the rod (at the end) from the booster to the brake pedal is a bushing used in conjunction with the pedal mounted stop light switch.
A lot of trucks had the plastic tube some also had rubber no ford part number but all the ones I have seen say bendix like the booster. It was just a dust cover and seal. The new reman boosters use a ribbed rubber boot to cover up the back of the booster and the push rod on the booster. The seal just prevents dirt and moisture from entering the moving parts of the booster.
Old Aug 19, 2009 | 06:02 AM
70_RangerXLT
I don't see it in the illustrations manual, but there is a tube approximately 3 in long x 1.5 in diameter that goes between the booster and the firewall.
The booster is mounted remotely from the firewall. This tube surrounds the push rod and seals the booster to the firewall.
I'll look a little further tonight and see if I can find a part number or illustration.
Old Aug 19, 2009 | 06:04 AM
NumberDummy
I assume what you are speaking of is the dust boot that fits to the booster the pushrod passes thru.
C3TZ2180A = is shown in the 1964/72 & 1973/79 truck parts catalogs for Midland Ross boosters on F350's.
Nothing is shown for the Bendix Booster.
I've never heard of a dust boot refered to as a plastic tube.
70_RangerXLT = 1973/79 Ford Light Truck Parts Catalog = Illustration Section 23, page 11 = 1974/79 booster & mounting parts.
Good luck finding this supposed tube. I looked in three parts catalogs, 1964/72 truck / 1973/79 light truck / 1973/79 passenger car: Zero, nada, nyet, non, nein.
Old Aug 19, 2009 | 09:50 AM
70_RangerXLT
I'm not sure what the correct description would be according to Ford, but it does exist. As I said before, I don't see it in the illustrations manual, but I'll look again tonight. This tube should have been used on all of the F100/250/350 trucks that used the Bendix booster.
It's not exactly a "dust boot". It's a plastic "tube" that has a flange and a seal on each end. The "tube" fits inside the booster and inside the hole in the firewall, and the flanges keep the tube from sliding into the hole. There is a seal on each end of the tube. This seals the booster to the firewall and encloses the push rod. The length of the tube corresponds to the distance between the firewall and the remotely mounted booster.
Old Aug 19, 2009 | 12:09 PM
mcdobson's Avatar
mcdobson
7279Ford, the other possibility is that you have a crack somewhere between the booster and the engine, and it just sounds like it is coming from inside.
If the booster you have is supposed to have a bracket behind it to space it away from the firewall, then maybe the rod is pushing too far into the booster opening a hole somewhere.?????
Old Aug 19, 2009 | 08:01 PM
7278ford's Avatar
7278ford
What you have described as the 3" x 1.5" plastic tube is exactly what I am talking about. You guys said that there are 2 seals that go on this tube and I have none. So I think that is what my issue is. I am having a hard time understanding how my booster could be bad when once the truck is stopped the air sound is gone. If the diaphragm was bad wouldn't you continue to hear the vacuum of the engine sucking air in from the cab? Also the air sound can only be heard when I am putting around the neighborhood or in a parking lot. I am more concerned with sucking in something into the booster than the noise and sounds like I am missing 2 seals.
