shock question
Old Aug 15, 2009 | 06:43 PM
Scottys-350's Avatar
Scottys-350
shock question
I have Reflex double front shocks on the front and singles in the rear. I am wanting to put Bilstiens on. will the 5100s work? when I went to shockwarehouse site it looks like these shocks(5100s) are for off road use. I only use my truck to pull an RV and drive around town.
Old Aug 15, 2009 | 07:59 PM
Stewart_H's Avatar
Stewart_H
Yeah, guys have 5100's on their rigs with no problems.
IIRC, the 5100 series is basically the same as the OEM replacement Bilsteins, with a few differences like longer travel, etc.
Stewart
Old Aug 15, 2009 | 08:07 PM
Scottys-350
Thanks Stewart, just wanted to make sure that when I ordered them, that I got the right type for the doubles on the front
Old Aug 15, 2009 | 08:19 PM
maevans's Avatar
maevans
Scott
I have 5100's on my early 99 that as a 2.5" mini pack on front (which doesn't change the stock shock length) and Airbags on rear.
These are the part#s Fronts- F4-BE5-6253-H5 Rears - F4-BE5-C336-HO
I'm thinking you should be able to double fronts with out any problems.
Hope it helps .
Old Aug 15, 2009 | 08:45 PM
Scottys-350
Thanks for the part# Maevans. I will give them a try.
