Lunati cams
Old Aug 15, 2009 | 11:38 AM
bmf316's Avatar
bmf316
Lunati cams
does anyone have any experiance with lunati cams, I found one on summit that i'm thinking about putting in my 351W and was wondering if they were any good. i heard that i should stay away from comp cams...
Old Aug 15, 2009 | 11:48 AM
lew52's Avatar
lew52
I don't have one but alot of people are using them , havn't heard anything bad about them ....Lew
Old Aug 15, 2009 | 12:17 PM
FL299's Avatar
FL299
Many years ago when involved with a pull truck - used Lunati - good at that time.
Old Aug 15, 2009 | 04:06 PM
Conanski's Avatar
Conanski
Originally Posted by bmf316
I heard that i should stay away from comp cams...
Why is that?
None of the Lunati cams I hve seen are compatable with the truck SD EFI system... just so you know, if you have mass air then you're OK.
Old Aug 15, 2009 | 04:57 PM
lew52's Avatar
lew52
I agree with that , there cams are made more for hi performance mass air motors ... Lew
Old Aug 15, 2009 | 07:24 PM
bmf316's Avatar
bmf316
well i am building up a 351W to replace my 302 and want to put in a more aggressive cam with more low end torque. I am having trouble finding ones that will work with the stock computer though. I was originally looking at one from crane cams on summit http://www.summitracing.com/parts/CRN-444232/ , but i found out that crane cams apparently went out of business. so i found one from lunati that claims it will work with the stock computer http://www.summitracing.com/parts/LUN-310A1LUN/ , my engine is a 90 351W w/o mass air...
Old Aug 15, 2009 | 08:28 PM
Jay54's Avatar
Jay54
Look at the summit cam sum-k4400. It's 99.95 with lifters and 3 degrees of duration less @ .050 then the lunati which you would never feel in a truck. I have ran 3 different summit cams over the years in different vechiles and have loved them all. I plan on running that one in my truck when I go through the engine next month.
Jason
