5 speed trans. ID
Old Aug 15, 2009 | 12:57 AM
Bigblack Ford's Avatar
Bigblack Ford
5 speed trans. ID
does anyone know the specific name of the 4 speed with overdrive manual transmission? its a 1993 f150 with the 4.9. i plan on swappin a 351W with gt40 heads and a comp cam soon and need the bell housing, my donor truck had an auto trans.
Old Aug 15, 2009 | 01:29 AM
BucksTrucks's Avatar
BucksTrucks
All the 5 speeds put in these trucks were on piece bell/trans units. There was the M5ODR2 and the ZF42 5 speed. The ZF is the one you want for a 351w.
Old Aug 15, 2009 | 09:03 AM
Conanski's Avatar
Conanski
Well the 4.9/5.0/5.8 all use the same bellhousing bolt pattern so the trans you have will bolt right up with the appropriate flywheel.
Old Aug 15, 2009 | 10:06 PM
Bigblack Ford
well i bought an entire parts truck but i havent picked it up yet. its an automatic trans. so your sayin all i gotta do to put the 351 in is swap motor mounts the radiator wiring harness and computer?
