Sponsored by: Real Truck
engine light
Old Aug 14, 2009 | 10:03 PM
carrollti's Avatar
carrollti
engine light
My engine light came on today. all guages looks good. no loss of power or anything else. what does this light mean and what would be the fix?
Tim
Old Aug 14, 2009 | 10:08 PM
F350-6's Avatar
F350-6
Welcome to FTE. The light means there is a code stored in your PCM. Depending on what year truck and which motor you have, you might be able to get the code scanned for free.
With no other symptoms to go by, you'll need to get the codes read to figure out what the issue is.
Old Aug 14, 2009 | 10:13 PM
carrollti's Avatar
carrollti
2004 6.0 psd
Old Aug 14, 2009 | 10:23 PM
F350-6's Avatar
F350-6
Then you've got to find someone with a good scanner. The inexpensive ones available at the parts stores won't read most of the codes in a diesel. You might try to swing by a parts store and have them do the free scan to see if you get lucky. I think the cheap scanners can pick up emissions codes like from the GPCM.
If you don't know someone with a good scanner, you might need to take it to a independent diesel shop or the Ford dealer to get the codes read.
Old Aug 14, 2009 | 10:24 PM
F350-6's Avatar
F350-6
