Accelerator Problems
Old Aug 14, 2009 | 12:10 PM
DockHoliday's Avatar
DockHoliday
Can anyone help solve this problem...2000 F-250 Diesel P/U 4x4. At idle the accelerator is dead. If I stomp on it several times it will start working again. Once slow to idle, as when pulling up to a stop sign, the accelerator doesn't work again. I have checked the oil, replaced the fuel filter, the air filter and the pedal position sensor. It is still doing it. The engine runs fine the accelerator pedal is just dead. If I put it into neutral as I pull up to a stop sign are reve it up it will stay ingaged. Any help??
Old Aug 14, 2009 | 12:45 PM
DieselBeast01's Avatar
DieselBeast01
I was going to say throttle position sensor, but you have already checked that. mine did the same thing and the sensor was my problem.
Old Aug 14, 2009 | 02:07 PM
DockHoliday
Did you have to reboot the system? If so, I don't remember how many time to turn on & off the ignition. Do you know?
Old Aug 14, 2009 | 02:59 PM
fifthwheel01's Avatar
fifthwheel01
RE-boot?? Reboot (got to have 10 characters)
