need help wont start
Old Aug 14, 2009 | 09:53 AM
zman1202's Avatar
zman1202
the fuel line from the back of the fuel filter has a wire out of it what does this wire from the fuel line control.
Old Aug 14, 2009 | 10:11 AM
jedstamm's Avatar
jedstamm
Are you talking about the fuel line from the back of the filter housing that screws into the IP? These engines aren't that sophisticated. A wire from the fuel filter would have no bearing on whether or not the vehicle will start. When you turn on the key, do you hear a click? You might not be getting any "juice" to your fuel shutoff solenoid. If not or if your fss is out, your vehicle will not start.
Old Aug 14, 2009 | 01:42 PM
joe f350's Avatar
joe f350
the wire on the line that goes from the lift pump to the flitter head is a fuel heater if i rember right it was a option i disconecked mine have u check the return lines on ur injectors
Old Aug 14, 2009 | 11:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle
It is a fuel heater, unless you are in a very cold location, you don't need it.
