Towing Problem AGAIN!!!
Old Aug 14, 2009 | 12:21 AM
btm991's Avatar
btm991
We were getting ready to leave on a trip to the river and right whenb we were pulling out of the driveway the service enginge soon light came on. We left anyways but while going up the cajon pass it would only get to 65 mph with it floored.
the truck is a 2007 6.0psd cc long bed. We were towing 2 sea doos
We have already had the turbo and ficm replaced.
Any ideas on what could be wrong would be great.
Old Aug 14, 2009 | 05:55 AM
cmcowboy's Avatar
cmcowboy
It could be a number of things, what kind of boost numbers where you getting? Someone else may chime in here so some good ideas. But you may just have to have it plugged in and retrieve the code to figure it out.
Old Aug 14, 2009 | 12:21 PM
btm991's Avatar
btm991
the boost psi was somewhere around 25psi when going up any kind of grade
Old Aug 14, 2009 | 06:38 PM
cmcowboy's Avatar
cmcowboy
Sounds like you may have to have some more warrenty work done it. I would just take it to your ford dealer and have then plug it in since the cel is on.
Old Aug 14, 2009 | 08:12 PM
jboczar's Avatar
jboczar
Turbo boost specification MY 2004-2007 is a minimum of 25 psi in 3rd gear, wot, under load (uphill, towing a load, etc). If its above that then your boost is ok.
Old Aug 15, 2009 | 02:59 AM
btm991's Avatar
btm991
25 psi was around the highest it hit
Old Aug 15, 2009 | 03:42 PM
btm991's Avatar
btm991
just got a call from ford said that there were codes for the turbo again and also codes for the fuel pump
Old Aug 18, 2009 | 06:47 PM
btm991's Avatar
btm991
truck was supposed to be ready today but ford called and said they replaced a sensor for the fuel pump, and cleaned the carbon out of the turbo, but they are still getting a code for the turbo. The turbo is only 4 months old. should they even have to be cleaning it out yet?
