cooling question???
Old Aug 13, 2009 | 08:19 PM
tygerrrr's Avatar
tygerrrr
Question cooling question???
hey i just installed a 87 460 in to my 69 f100 and the motor is to close to the rad to run the mechanical fan so i need to get a electric fan that can keep my truck cool in the hot summers. heres a little info. i have the stock water pump and i just bought a new three core rad. please help me with my big problem. thx tyger
Old Aug 14, 2009 | 01:14 PM
Bear 45/70's Avatar
Bear 45/70
Well first, a 4 core would have been better than a 3 core. As to electrics, just get the highest CFM one you can find. It will probably be a dual fan set up.
Old Aug 14, 2009 | 03:44 PM
Beechkid's Avatar
Beechkid
if you check into the Police Crown Vic/Mustang or Continential LSC model, they had very high flow electric fans and cost less than aftermarket units that flow less cfm.
Old Aug 14, 2009 | 04:34 PM
tygerrrr's Avatar
tygerrrr
so i found one that came out of lincolin mark 8 and is says it blows 5000 cfms is that a nuff or should i mabey get a different water pump to???
Old Aug 14, 2009 | 05:42 PM
75F350's Avatar
75F350
Try that fan that you have now. Those move quite a bit of air. YOu should not have any problem pulling enough air, but you may have some difficulty with having enough rows in the radiator for the proper amount of heat exchange.
There is no magic formula really, you will just have to run it and see.
Keep a good eye and use a quality gauge. Small steps will produce your answer.
Old Aug 14, 2009 | 06:43 PM
tygerrrr's Avatar
tygerrrr
kk thx i just put a new sunpro oil temp gauge in it is that going to be ok. and what is a good oil temp??
Old Aug 14, 2009 | 10:27 PM
Bear 45/70's Avatar
Bear 45/70
Oil temp goes up way slower than water temp. I would rather have a good water temp gauge than an oil temp gauge.
Old Aug 15, 2009 | 04:29 AM
tygerrrr's Avatar
tygerrrr
U think I could put the oil temp gauge in the water instead???
Old Aug 15, 2009 | 08:46 AM
C-Leigh Racing's Avatar
C-Leigh Racing
Bear,
maybe he has oil in the radiator instead of antifreeze, ooooh god, hope antifreeze not in the engine.
Just shootin the bull
I cant remember if it was here or 460.com, but a guy had the two fan set up pushing air through, & wasnt enough to keep the temps down on the engine. May have been the pushing of air or the amount of his engine build he had was the problem & I dont remember if he got it sorted out or not.
Neil
Old Aug 15, 2009 | 09:52 AM
Bear 45/70's Avatar
Bear 45/70
No, get water temp gauge instead.
