Shutoff problem
Old Aug 13, 2009 | 02:39 PM
Rancheroracer's Avatar
Rancheroracer
Shutoff problem
My truck did it again last night, under full throttle it just shuts off, no response from acc. pedal, wrench light on dash came on. Had to turn off key & restart, then it runs ok, wrench light off. Happened a couple months ago & local dealer replaced the electronic throttle control body, it showed a trouble code. This time he said no code so they didn't do anything, he said it could be your Edge Insight, which I don't think it is. Anyone else have this problem or any advice? I suspect it is a computer problem.
Old Aug 13, 2009 | 03:36 PM
pb34's Avatar
pb34
Doesn't the Edge Insight just have gauges and read codes? If that's the case then it can't be the cause of the problems. I'm not quite sure what it could be but it isn't that if it only has gauges and reads codes.
Old Aug 13, 2009 | 03:46 PM
Rancheroracer
Yes, it's only a monitor. I have it mainly for trans. temps., etc. It's supposed to be able to read codes although it didn't show the trouble code the first time. I don't think that's what it is but they wanted me to leave it unhooked to check. Only problem with that is it took 2 months for it to happen again.
