rim question
Old Aug 12, 2009 | 10:51 PM
mjshagnaty's Avatar
mjshagnaty
Question rim question
will the rims off a newish f250 fit on a 69 f250
Old Aug 13, 2009 | 08:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Thru 1996 on F250/350's, after that Ford went to metric wheels.
Econoline (E250/350) wheels didn't go metric till circa 2003.
Non metric: 1969/74 E300 / 1975/2003 E250/350 / 1953/1996 F250 / 1967/96 F350: 8 lug, 6.50" bolt circle.
Old Aug 13, 2009 | 09:01 AM
MotorDog's Avatar
MotorDog
What is a "newish" rim? If you mean anything after 1996 the answer is "No." That was when they started making the rims with metric measurements and even though they look close, they don't quite fit over the lugs.
Number Dummy: Does that mean we could use the later Econoline wheels? I was answering this the same time as you were. You're quick on the draw this morning..............
