Fuel Pump Question
Old Aug 12, 2009 | 09:12 AM
CHIEFEAVES's Avatar
CHIEFEAVES
Fuel Pump Question
When had motor cleaned on the 51 F1 V-8 Flathead, the machine shop lost the rod from the block that pushes the fuel pump. Sense I am new to this forum, I would like some suggestions on where to find parts for the truck and also, what would this rod be called in looking for a replacement. I am not sure but think this is a 239 engine. Thanks for suggestions. Harley
Old Aug 12, 2009 | 10:25 AM
jmadsen's Avatar
jmadsen
your right, it's just called the fuel pump pushrod, I dont think I have seen any listed in lmc truck, dennis carpenter etc? maybe try Joblot NY or Vanpelts sales?
http://www.joblotauto.com/
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Im sure there others too but can't think of off the top of my head.
the very first flathead I took apart had 1 and a half push rods in it! old one must have broke in half and when they replaced it somehow fell into the engine?? took me a bit to figure out what that was and where it had come from
good luck
Josh
Old Aug 12, 2009 | 01:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you do a Google or Yahoo search on "fuel pump pushrod Ford flathead" you'll find many sources. Here's one
http://lbcunited.com/earlyford2/prod...57deeafd20a04b
Old Aug 12, 2009 | 07:54 PM
vintage tin's Avatar
vintage tin
macsautoparts.com.
part #EAB-9400-A $14.95.
try this ,i just looked it up.should be what you need.
Old Aug 12, 2009 | 08:40 PM
CHIEFEAVES's Avatar
CHIEFEAVES
Thanks for the info. I am sure I will other questions as I begin this restoration project in that I have no mechanic background.
Harley
