Sponsored by: Real Truck
Rear Crew Cab door closing issues
Old Aug 11, 2009 | 08:53 PM
420CREW's Avatar
420CREW
Exclamation Rear Crew Cab door closing issues
Went to shut the rear door today and it bounced open again. It appears that the latch does not always engage, Has anyone else had this problem and is there an easy fix. Not sure whats involved with replacement but it looks like a pain in the ***.
Old Aug 11, 2009 | 09:02 PM
I.B. Washincars's Avatar
I.B. Washincars
I don't know if it will apply in this case, but on older vehicles I've seen this happen a lot. Usually after washing the car/truck and wiping out the jamb area a latch would inadvertently get latched closed with the door open. With the latch already closed it would just bounce off the striker pin when attempting to close the door. The fix was easy, just pull the door handle and open the latch with your fingers.
Old Aug 11, 2009 | 09:46 PM
bayou barataria's Avatar
bayou barataria
My old truck used to do that, just put some wd-40 or some spray on grease and it will take care of that.
Old Aug 12, 2009 | 12:26 AM
Chaosracing's Avatar
Chaosracing
Clean the latch with brake cleaner first to remove old lube. When the lube gets old, it gets sticky and attracts dirt. Then use a spray grease to relube. WD-40, PB Blaster and stuff like that will only work for a little while.
Old Aug 12, 2009 | 02:36 AM
ford7379trucks's Avatar
ford7379trucks
some brake cleaners can eat paint so get the right brake clean
Old Sep 24, 2009 | 07:29 PM
420CREW's Avatar
420CREW
Update!!
Ok so today I went to close my rear door and no go now i have to tie the door shut from the inside looks like I may need a new latch anyone switched one out before? Any one know where to get one fast?
Old Sep 24, 2009 | 08:56 PM
I.B. Washincars
Your original post was 6 weeks ago, and you're in a hurry NOW ?
Old Sep 24, 2009 | 09:52 PM
420CREW's Avatar
420CREW
The wd 40 worked for awhile
