View Poll Results: What to do about Squirrels
Trap em
46.43%
Let the turbo suck them up
53.57%
Voters: 28. You may not vote on this poll
OH My!
Old Aug 11, 2009 | 11:31 AM
JackStewart's Avatar
JackStewart
OH My!
I don't use my truck all that much, drive it to work every so often. So yesterday i decided to clean the Air Filter and when I opened the housing the filter material was missing and in its place was a Squirrels nest. Replaced the filter and inspected the turbine inlet. can't see any real damage, turbo still developes full boost. I am trying to develope a plan to inspect the intake track but don't know what all to look at/for and what else I can do to minimze the damage to the engine from inhaling all of that junk. I have also replaced the Normal and Bypass oil filters. Any help sure is appreciated. Thanks!!
Old Aug 11, 2009 | 11:35 AM
just another truck's Avatar
just another truck
Wow, that would be wild to find.. Had you started the truck withthe nest in there? If not, sounds to me you should be fine.. If you started it withthe nest, then I have to step back and listen to some of the experts here. I am guessing you have cleaned all the way up to the turbo once you found the nest? WHat condition was the intake tube in?
Old Aug 11, 2009 | 12:00 PM
superduty4x4's Avatar
superduty4x4
If there is no damage on the compressor wheel you are probably fine. Throw a few dryer sheets under the hood (zip tie them to things) and it should help keep your nutty buddies at bay.
Old Aug 11, 2009 | 12:03 PM
03_PSD's Avatar
03_PSD
Man thats crazy, glad you caught this before you went for a drive.
Old Aug 11, 2009 | 12:14 PM
Hiflyer746's Avatar
Hiflyer746
While I would not actually suck up squirrels. . . the image kinda made me laugh
Timmy
Old Aug 11, 2009 | 12:16 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE Jack.
Man, you need to check these things more often. Have you thought about doing the 6637 mod? Them little creatures can't get in that one.
Old Aug 11, 2009 | 12:55 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
you need to add a 3rd option for the poll! blow them to smithereens.......
Old Aug 11, 2009 | 01:09 PM
87 F-150 I6's Avatar
87 F-150 I6
wow, that's strange and would have sucked!
Old Aug 11, 2009 | 01:16 PM
JackStewart
OHH yes, The truck has been driven. How long this condition existed I do not know. the turbo inlet looked oiley but no obvious damage to the compressor wheel. I am hoping all the oil in the intake track has captured the fine stuff in the intercooler. I believe I will be taking the intercooler off soon.
Old Aug 11, 2009 | 01:23 PM
JackStewart
I am not familiar with the 6637 mod. I have an aftermarket cold air kit that I am going to install a screen mesh over the intake...just for them:-)
Old Aug 11, 2009 | 01:24 PM
JackStewart
I was tring to be politically correct:-)
Old Aug 11, 2009 | 01:32 PM
miller_feed
What kind of intake did you get? Here is the 6637.
Old Aug 11, 2009 | 02:01 PM
husker's Avatar
husker
I also had pack rats build a nest in the filter box before I did the 6637. Even dryer sheets, and other "home remedies" won't keep those critters out if it sits long enough. I would go for a mesh screen on the intake if you don't change to a 6637.
Old Aug 11, 2009 | 02:13 PM
Billyclub's Avatar
Billyclub
I let my Jack Russel- Buck, take care of them. I flush them and he has a field day with them.
Old Aug 11, 2009 | 04:17 PM
Stewart_H's Avatar
Stewart_H
Oh dang. That's-a notta so good.
Stewart
