Question About Directonal Flasher
If it would not work, would some one have some information on where the flasher is so I can replace it with a heavy duty flasher?
If doing this is asking for trouble then i won't do it, I just like the instant on and off that LED's provide. Ever since i installed tow mirrors with the led's ive been wanting to change out the other lights. i also have a trailer with led tail lights and they just look so much cooler. thanks.
Just in case you're expecting your Truck to light up like a XMas tree.
I installed (so called) super bright LEDS throughout my Truck last year. They were replaced with standard bulbs only after a few days. I found LEDS do not work so well in the OEM light housings. The rear tail/brake is the worst. The front signals are better, but still not so great.
In daylight I would consider exterior LEDS installed in stock Ford light housings dangerous. They are simply not bright enough.
Maybe someone here can offer a better LED product, but I was convinced the ones I purchased were the best available at the time.
If you do install a set at least take a good look at them in the daylight. Install one side and do a daylight side by side comparison and judge for yourself.
I think your hard earned money could be spent smarter on something else you might want for your Truck. Headlight upgrade?
Rick...
http://cgi.ebay.com/2x-RED-36-LED-BR...d=p3286.c0.m14
i was nervous buying bulbs from overseas, but they have been going strong for over 3 years and 57,000+ miles, with my parking lights on 90% of the time i drive. here's a quick vid of one in action:
http://s154.photobucket.com/albums/s...t=1b69e95d.flv
All the visual testing I did with the LEDs was in direct sunlight so maybe my recommendation of not using LEDs is a bit strict. I just found the standard bulbs brighter to my eyes in direct sunlight.
I'm not even very impressed with the interior dome LEDs I have installed.
Rick...
you need LED's that have side-facing diodes, such as these:
