2003 engine noise on start up.
Old Aug 10, 2009 | 07:53 PM
jrank's Avatar
jrank
I have a 2003 expedition 5.4 engine.On the first start up of the morning after it has set all night,the engine makes a rattling noise for a few seconds and then the noise stops.It doesnt make the noise the rest of the day.Any ideas?I use motorcraft oil filters.
Old Aug 10, 2009 | 07:57 PM
alloro's Avatar
alloro
That's normal, it commonly called piston slap and these motors are well known for having it.
Old Aug 10, 2009 | 08:16 PM
TexFinn's Avatar
TexFinn
Piston slap is quite possible. However, just to make sure, are you sure you have enough oil?
Old Aug 11, 2009 | 09:27 AM
04markIII's Avatar
04markIII
could be the a/c compressor as well. if you left it on when the truck was turned off, it makes a shudder type noise on next startup. tsb for it. no fix except to make sure compressor isnt running when you turn the truck off. found that out AFTER i had the complressor replaced!!
Old Aug 11, 2009 | 10:04 AM
jrank's Avatar
jrank
Thanks guys,Its full of oil and its not the ac.I just know it doesnt sound good.Cant be good on the engine!
Old Aug 11, 2009 | 10:39 AM
alloro's Avatar
alloro
http://f150online.com/forums/v8-engi...n-summary.html
