Help
Old Aug 10, 2009 | 03:11 PM
jiggersup's Avatar
jiggersup
Help
I need some valuable info on how to check the glow plug relay and also how to know if the control mudule is bad.
Thanks,
jiggersup - 1999 f250 - 7.3 powerstroke
Old Aug 10, 2009 | 03:59 PM
DND58's Avatar
DND58
Welcome to FTE. Here's some good reading from another post about your GPR question.
https://www.ford-trucks.com/forums/7...pr-system.html
I'm not sure of you question about control module. Could you explain further about what is or isn't happening. Others will be along soon.
Old Aug 10, 2009 | 08:42 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Unplug the connector on the outside of the valve cover. You'll see 9 flat pins inside there. They're laid out as follows G G I I C I I G G
where
G=Glow Plug
I = Injector
C= Injector Common
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
To check glow plugs Test between "G" and battery ground. Should be between 0.1 and 2.0 Ohms
If you find readings that are out of spec, then yes it's time to pull the valve cover and check the connector.
(I just cut and pasted this info from Chris (F350-6)So give him some reps)
Old Aug 12, 2009 | 12:45 AM
jiggersup's Avatar
jiggersup
wow, ok, thanks very much.
jiggersup
Old Aug 12, 2009 | 12:52 AM
rblaine9000's Avatar
rblaine9000
Hey jig I don't know what year truck you have but all you have to do is turn the key on and test light both sides of your relay of the large wires. The relay is basicaly a large solonoid like on any other ford firewall! if this did'nt help than follw the links dnd58 sent
Old Aug 12, 2009 | 12:55 AM
jiggersup's Avatar
jiggersup
thanks rblaine i will try that too
