Sponsored by: Real Truck
Body Controle Module-HELP!!
Old Aug 10, 2009 | 01:37 PM
AZJD's Avatar
AZJD
This is my first post here, but not the first V10. I recently got rid of my 6.0 diesel piece of **** and fell in to a smokin deal on a very clean 1999 F350. One problem...the door locks (all four) do not work. I can hear them click, but no worky. The original owner was a certified ford mechanic and the truck came with all the service records. He now lives out of Phoenix, but he says he removed the Body Control Module (BCM) behind the stereo after it was broken in to. I pulled the stereo and found a pack of what looks like four relays with one missing at the end??? Does this sound right? I know the actuators go bad, but all four our not working. Please help. Thanks, Jason
PS- This is a great informative forum. Thanks in advance!
Old Aug 11, 2009 | 11:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the Superduty forum. You'll get lots more answers here
Old Aug 11, 2009 | 02:04 PM
Monster-4's Avatar
Monster-4
If you hear them click it sounds like everything up to the actuators is good and all the actuators are bad. It's possiable and is actually pretty common. You can either replace them all or fix them for nearly free.
https://www.ford-trucks.com/forums/4...cks-fixed.html
Old Aug 11, 2009 | 03:18 PM
AZJD's Avatar
AZJD
I am super familiar with the actuator problems, however, this guy swears he pulled the Body Control Module out?? I would just like to find out where this is before I go pulling panels off. Can anyone link me to an electrical diagram showing the BCM. I cant seem to find any info on this.
Old Aug 11, 2009 | 03:39 PM
ljstoy's Avatar
ljstoy
If your truck has keyless entry, Chilton's Manual says you have a "Generic Electronic Module". It doesn't say where it is but it has a pink/lt green, pink/yellow, pink/lt blue or violet/lt blue and lt green/yellow wires (4) coming out of it. The relays that you're looking at could be the park lamp, driver unlock and 2 all unlock relays.
If your truck doesn't have keyless entry, those 4 relays and the GEM, don't show up.
That's all that the Chilton book will show me.
Old Aug 11, 2009 | 05:06 PM
AZJD's Avatar
AZJD
Thank you. I think this is what I was looking for. Is the relay farthest to the pass side one of the all unlock relays. If so does it say what size relay this is?? I am missing one in a row of four. This has to be it. THANK YOU FOR YOUR INPUT
Old Aug 11, 2009 | 08:35 PM
ljstoy's Avatar
ljstoy
yes, it appears to be the two closest to the pass. side. It doesn't say what size but they run off of a 20 amp fuse (#26 I think). Sorry, I picked this up today to help with my 08 4wd switch w/ no luck. I wish I had a Haynes manual but this is all they had.
rackhound
Oct 11, 2024 01:05 AM
Bombero
2004 - 2008 F150
Jul 9, 2010 07:48 PM
evilwayz7
New Member Introductions
Sep 4, 2007 06:00 PM
FXSTC
Arizona Chapter
Apr 10, 2007 10:22 PM
ecajberry
Sep 29, 2004 08:34 AM
