Oil level dropped, need help
Old Aug 10, 2009 | 08:27 AM
omontoya361's Avatar
omontoya361
can someone please help!!!!!! i was driving my 99 ford ranger when i noticed my oil level was on L , engine got noisy and shut down. did my oil pump fail or is it something more simple, need answers quickly as i use my truck to get to work and back. (2.5 L. 120k mil.) engine did crank over after it cooled down, actually started i'm ready to change oil pump , any advice would help, thanks
Old Aug 10, 2009 | 06:11 PM
Bill W's Avatar
Bill W
Does your truck have a oil gauge or a light?
This is what i would do.... buy an oil filter and your brand of oil for your truck and change it, then start the truck and see what happens. If the engine is still making a lot of noise i would find another way to work. You may want to spring for an oil additive like Lucas or Zmax. Are you in AZ?
Old Aug 10, 2009 | 07:28 PM
omontoya361
help
yes it moves from below L to L only. would oil pressure switch cause no oil to get to motor? motor completely stalled, does start but still has no pressure. i don't want to keep cranking for fear of causing more damage.
Old Aug 10, 2009 | 07:50 PM
Bill W's Avatar
Bill W
You are right it will cause more damage if you run it the way it is.
Question.... whaat year is your truck? what motor? how many miles?
Old Aug 10, 2009 | 08:51 PM
omontoya361
help
it is a 99 ford ranger, 2.5 lit., has 127,ooo miles on it .
Old Aug 10, 2009 | 08:58 PM
omontoya361
help
by the way i live in tucson az., on the southside.
Old Aug 10, 2009 | 09:21 PM
Bill W's Avatar
Bill W
Cool! well see if some of the guys in the Ranger forum can help out from here.
Did it run low on oil?
Old Aug 10, 2009 | 09:32 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
omontoya361, I'm going to move this to the Ranger forum to see if you can get the answers you are seeking.
Thanks Bill!
Old Aug 10, 2009 | 10:59 PM
Old93junk's Avatar
Old93junk
Whats the oil level on the stick, right now?.........How about coolant? did it overheat? If you pull out the dipstick, does the oil on it appear to have metal flakes in it?
Old Aug 11, 2009 | 08:28 AM
omontoya361
help
oil level showing full , yes has coolant, no did not overheat. what could problem be other than bad oil pump? is there something easier to replace before i tear apart motor to get to oil pump? (99 ford ranger 2.5 lit.) don't want to take to a shop and be taken for a ride, like i've said before gauge moves from below L to L only and motor will start but sounds dry ( no oil getting to motor)
Old Aug 11, 2009 | 09:48 PM
Bill W's Avatar
Bill W
I would do this, pull the coil wire and then pull the valve cover, crank it over and see if oil is pumping to the top end, If not, stop and go to plan B
Old Aug 11, 2009 | 10:04 PM
carsrus's Avatar
carsrus
Does it just crank or does it actually run? It could be the timing belt is broken and not spinning the pump. But if it runs then its not the belt.
Could also be the pickup screen in the oil pan.
Old Aug 12, 2009 | 07:51 AM
omontoya361
thank you all!!!!!!
this is what i did and it seems to have worked (to my surprise) i put in a new oil pressure switch, cost 5.99 !!!!!! , this is saving me 100s of dollars as i was ready to put in new oil pump . thank you all for your advice !!!!!!! i really appreciate it
Old Aug 12, 2009 | 05:09 PM
g_k50's Avatar
g_k50
Nice, good job, sending unit either shows pressure or no pressure, the gauge is an idiot light disguised as a guage. It shows pressure unless the pressure is less than 8 psi, and then it shows no pressure, it's not like it shows L when the pressure is 15 psi and just above L when the pressure is 20 psi, or tops out when the pressure is 86 psi.
My 1999 Service Manual says to replace the sending unit, if the guage still is out of calibration replace the guage. That's it two steps. Nuff Said.
Old Aug 12, 2009 | 10:08 PM
rootbeer's Avatar
rootbeer
............The defective oil pressure switch must have shut the engine down like it is supposed too ! How often do you change your oil and filter ? rb
