Sponsored by: Real Truck
stuck
Old Aug 10, 2009 | 12:08 AM
beamer30's Avatar
beamer30
stuck
is there a trick to getting the rim off a 2008 f350
Old Aug 10, 2009 | 12:43 AM
fordf150guy's Avatar
fordf150guy
kick it from behind while truck is supported by jack stands.
Old Aug 10, 2009 | 12:56 AM
beamer30's Avatar
beamer30
so the lug nuts are the only thing that holds the rim on
Old Aug 10, 2009 | 01:43 AM
fordf150guy
yup, all 8 of them.
Old Aug 10, 2009 | 09:02 AM
Stone Mathews's Avatar
Stone Mathews
I've had this happen before. Spray a bunch of PB Breaker behind the rim, along the rim-to-rotor interface. Just don't get the PB all over your break pads, calliper, rotor breaking surface, etc. Let her set for a while, then try to knock it off with a rubber mallet.
Stone
Old Aug 10, 2009 | 02:26 PM
weyland426's Avatar
weyland426
omg, I hope FTE has a liability disclaimer...
Old Aug 10, 2009 | 02:57 PM
Wagion's Avatar
Wagion
Get a bigger hammer seriously.
PB blaster
2x4
sledge
Jack it up, Make sure it is secure, Beat on it from behind like its a rented mule
Some other methods you can try I don' recommend.
put 4 lug nut back on hand tight then back off one turn drive around slowly bumps are good thing.
brace a 4x4 off the other wheel or frame and use a bottle jack against edge or rim.
When you do get it off. (It will come off just might take some doing and even a few days of dousing with PB blaster.) smear anti seize on the inside of the rim before you replace it or get one of the plastic inserts.
Is this a AL rim?
