Sponsored by: Real Truck
o2 f250 trailer plug
Old Aug 9, 2009 | 03:21 PM
mickpowell1967's Avatar
mickpowell1967
trying to get voltage to my center post of my oem mounted trailer rec
is there any other fuse other then the on in the cab fuse panel.i was told there was on under the hood on left side
Old Aug 11, 2009 | 04:35 PM
bobh's Avatar
bobh
trailer 12v pin
On My 2000 f350 v10 there is a relay and a 30 amp fuse under the hood
in the fuse box on the left side by the master cylinder. The relay operates
when the ignition switch is on.
Old Aug 11, 2009 | 08:42 PM
mickpowell1967
i have a relay and fuse in my fuse panel in the cab under steering colum, still not working
Old Aug 11, 2009 | 11:06 PM
JCark's Avatar
JCark
Hope This helps
The center pin on superduty's is the reverse lights, check 4 and 38 (under hood), and 28 (Under Dash). Hope this helps!! I just recently went through this with my truck.
Old Aug 12, 2009 | 12:22 AM
Chaosracing's Avatar
Chaosracing
I had this happen to my 02 as well a couple of years back. Found out a chipmunk chewed the wires next to the firewall. Fixed the wires, fixed the chipmunks. Gotta fix the chipmunks again this year.
