Fuel pump issue?
Old Aug 8, 2009 | 01:07 PM
BlueTorpedo85's Avatar
BlueTorpedo85
Fuel pump issue?
I have an 85 F-250 351w that has been sitting for about two years. It seems to be starving for fuel as when i crank the truck and press the gas the bowl in the carb does not fill. Today I took the lid off the carb and filled the bowl by hand and the truck fired right up. Ran well for about a minute, and then started to act as if it was starving. When i press the gas in the truck, it will rev, but the engine speed drops immedietly and the truck almost stalls. I'm guessing it is a bad fuel pump but I wanted all of your opinions to validate. Thanks
Old Aug 10, 2009 | 09:55 PM
Franklin2's Avatar
Franklin2
If you have fuel in the tank, then I would guess it's the fuel pump. If you want to make sure, take the rubber hose off the inlet of the pump, and put a longer one on that will reach into a can of gas sitting under the truck.
jor1369
2009 - 2014 F150
Jun 15, 2014 09:02 PM
hermancm
May 10, 2014 10:50 PM
triskit16
24
Sep 19, 2013 08:55 AM
clouden
Mar 1, 2010 10:29 PM
StevenK
Jun 6, 2005 10:44 AM
