Anyone know what the oil temp would be in an engine with coolant temp at 210 deg? Would oil also be around 210? I could install a gauge, but it seems that oil temp would be pretty stable once engine warmed up. Thanks.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
I have sensors in the oil and tranny pan. The oil tends to run the same as Radiator (195 degrees) untill you get to running down the highway on a hot day. Then it may go as high as 215. I also have a small oil cooler.
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Tranny stays a lot lower normally. Again on a hot day pulling a load it may eventually get to 210. It also has an auxillary cooler. Both coolers are mounted horizontally due to space restrictions in front of the radiator. Any higher than 210 on oil or tranny worries me. I also run a large tranny fluid pan.
Cool is Cool!
Bear Tracks
1977 Ford F-100
400m/c6
280,000 miles
