C-6 Transmission ??
Old Aug 7, 2009 | 09:43 PM
bsw9323's Avatar
bsw9323
C-6 Transmission ??
I am going to show some ignorance here but, will a c6 trans bolt up to a 351 windsor. I always thought these were big block trans. Thanks
Old Aug 7, 2009 | 11:12 PM
Mustang6147's Avatar
Mustang6147
I am not much of a C6 fan... but I would think, the c6 would fit many aplications... That being said, do they have different B-housings?
I would think so, but am going to watch this thread for info to.
Old Aug 7, 2009 | 11:43 PM
arctic y block's Avatar
arctic y block
The C6 as I know it does not have an interchangeable bell housing. It is a one piece case. It has a different bolt pattern case at the bell for different applications. I do not remember for sure if it has the 302/351W pattern or not stock.
Old Aug 8, 2009 | 01:01 AM
RichS2659's Avatar
RichS2659
Yes, the C-6 comes in a small block bolt pattern, as I have one sitting in a 82 Club Wagon with a 351W. You just have to find one with a small block case. If you want a 2wd C-6, check in vans, as they came with 300's and small blocks more.
Old Aug 8, 2009 | 12:03 PM
hogworkzinc's Avatar
hogworkzinc
DentsideAholics
I agree, they are around. Saw one on craiglists this am for $125.
Old Mar 9, 2022 | 11:52 PM
Danzin's Avatar
Danzin
There are AT LEASE 3 Versions of the C-6. There is a Big Block 360-390-429-460 version.
There is the small block 302/351 Version.
There is also what some call the tall case-industrial version for 352-361-391-and I believe 428 version. These last ones are virtually extinct.
The C-6 is an awesome easily rebuildable transmission which can be done at home with few special tools however the bellhousings are not removeable/interchangeable.
Old Mar 10, 2022 | 05:35 PM
85e150's Avatar
85e150
https://www.transmissionrepaircostguide.com/c6/#Housing
