Dimensions
Old Aug 7, 2009 | 01:47 PM
Huntfamily53's Avatar
Huntfamily53
Originally Posted by Alcaeus
I have a compressor I just dont have alot of air tools. air for my tires is about it What kind of air tools should I go for?
Cutoff wheel, air chisel, ratchet/impact gun, sander, paint gun, die grinder... I get all mine from HF yeah, some stuff is garbage but good for what I need.
I called the DMV and they said that as long as I am taking it apart to rebuild I only need the title. I do however need a level one inspection because it is from out of state. That means that I will have to get it to a DMV site for the inspection if I cant get an officer to stop by and do it fo rme. it is free for the inspection and I dont need to register it or insure it.
My Frame VIN will not match my Door VIN after I am done.
Has anyone had a problem with that? Did you all get rid of the vin on the frame or what?
I don't think the vin is on the door on the 56? On my 53 it is a plate in the glovebox rivited on. Just drill out the old rivets and put on the needed vin tag that matches the frame.
Good luck with it.
Old Aug 7, 2009 | 02:49 PM
jmadsen's Avatar
jmadsen
PM sent. I just re-read the above, sounds like you got one and its settled on?
Good Luck
Josh
Splash67
Aug 6, 2017 08:00 AM
Azuretruck
Aug 4, 2016 08:35 PM
chzuck
Jan 19, 2012 07:14 PM
BobbyB247
Jan 2, 2012 05:48 PM
seke41
1983 - 2012 Ranger & B-Series
Jul 20, 2004 01:15 PM
