429 with a ZF
Old Aug 5, 2009 | 10:42 PM
Bossman89's Avatar
Bossman89
429 with a ZF
Hey yall! I have an old project I never got to finish and need help on some facts. I have a 429 that came out of a '68/69 ltd that I was going to swap into my 89 f150. I already rebuilt the motor and its been sitting in the corner for a couple of years and I'm sick of looking at it. My issue is a trans because I would love to put a zf 5 speed out of a 90's 460 f250/350 but wondering about the flywheel. I know the bolt pattern should be the same for the trans but how should I get a flywheel . I believe the zf's use an 11 inch flywheel but did they change the bottom end balance of the 429's and 460's like the small blocks . The motor rebuild is fairly mild so the power shouldn't increase that much. I really would like to use this trans instead of the c6 so I can have an overdrive. Thanks in advance for any help.
Old Aug 6, 2009 | 10:07 AM
mcdonaldm's Avatar
mcdonaldm
they went to external balance in 79 (some mid 78's also). the pre 79 engines used internal balance so you cannot swap the flywheels/flexplates between the two.
not sure what is needed, but maybe someone else can pipe in with the correct flywheel choice.
the other option is to use a flywheel from a newer 460 and get it neutral balanced by a machine shop. that should work also. not sure how much it would cost to do that mod.
rgds
Mike
Old Aug 7, 2009 | 01:52 PM
Bossman89's Avatar
Bossman89
Thanks for the reply mcdonaldm. I contacted my machine shop and they said they could balance the bottom end to make it work rather cheaply so now all I have to do is gather the parts and see how it goes.
