1950 ford truck issues
Old Aug 5, 2009 | 04:10 PM
timterri's Avatar
timterri
Does anyone know what the orginial 9 inch rear end spline is, is it 28 or 31
Or an easy way for me to tell?
Thanks
Old Aug 5, 2009 | 04:33 PM
havi's Avatar
havi
I'll have the Roast Duck
Welcome to FTE !! 1950 would be either a dana 41 or 44 stock. The simple 9" swap-in would come from a '57-60 Ford pickup, of which more often than not is a 28 spline.
Old Aug 5, 2009 | 04:43 PM
Old F1's Avatar
Old F1
From kevinstangs (more then you ever wanted to know about 9 inch diffs) site;
A method to identify 28 spline axle shafts can be by looking at the center brake hub area, a rectangular slot in the center will indicate 28 spline axles.The 31 spline axle shafts will have a different appearance, with one small center chamfer and two outer holes in the center hub, however, 28 spline shafts can also appear like this to, so it does not always indicate 31 spline shafts.
http://www.kevinstang.com/Ninecase.htm
Old Aug 5, 2009 | 05:28 PM
4tl8ford's Avatar
4tl8ford
The original 1948-50 rearend should be a 19 spline axle.
