Sponsored by: Real Truck
5.4 shuts down
Old Aug 5, 2009 | 03:41 PM
RIF350guy's Avatar
RIF350guy
5.4 shuts down
During normal driving condition my 2005 F 350 5.4 will occasionally shut down. I happened last week, and late 2008 the last time it did it. Any idea what is causing this?
Old Aug 5, 2009 | 04:24 PM
Mustang6147's Avatar
Mustang6147
Boy it beeing that intermittent... It could be anything.
When it shuts down are you brakeing at all, or simply 50mph and she cuts out, then it restarts imediatly. or does it take aminute.
Old Aug 5, 2009 | 05:57 PM
Monster-4's Avatar
Monster-4
Mustang has some good questions. We need more details to properly help you out.
Old Aug 5, 2009 | 07:00 PM
Fordfanatic4life's Avatar
Fordfanatic4life
aftermarket alarm/starter interupt installed by chance ???
asking cuz its surprizingly common for aftermarket alarms to shut ur engine off for no reason..was having that exact issue with my Ford Taurus awhile back..
asked a mechanic at work, he said try removing the alarm.. sure enuf after we took it out the car never "mysteriously" shut off again...
Old Aug 6, 2009 | 10:25 AM
RIF350guy's Avatar
RIF350guy
Sorry it took so long to post again... working nights... bummer!
It seems to be most common in the 25-35 mph range. Its only happened on back roads.
I'll just be cruising along, no load, take my foot off the accelerator for few seconds, and when i go to get back on the gas.... nothing, i look and the little wrench light is displayed on the instrument panel. I throw it in neutral quick, and it will restart, but it turns over longer than normal.
No aftermarket electrical accessories on the truck.
Old Aug 6, 2009 | 11:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'd say IAC, but the fly-by-wire 3-valver doesn't have one.
Old Aug 6, 2009 | 12:17 PM
Monster-4's Avatar
Monster-4
My uncle had a similiar issue in his Ranger. Turned out to be a loose ground wire. He'd be driving along fine then all of a sudden it shut down. Usually it would fire right back up. It wasn't until it wouldn't start one time that we started tracing ground wires. Found one loose and pretty rusted up. I would at least check that out. Something simple to at least elminate.
Old Aug 6, 2009 | 01:29 PM
RIF350guy's Avatar
RIF350guy
Loose ground wire sounds like a good start. I'll poke my head around and see what I come up with.
Any suggestions for a good battery... I'm sure it'll need a new one before the winter. I do plow with the truck.
