1978 f100 compressor swap
Old Aug 5, 2009 | 08:29 AM
jeff gammon's Avatar
jeff gammon
I have a newer donar truck (1993) with a serpentine belt setup and a sandren type compressor. The compressor is shot on my 78. If I swap all the accessories from my newer truck to my 78 will the newer compressor work with all of the old a/c stuff on the old truck? IF so how can I make the hoses hook up? I saw a conversion Kit on Ebay where you could change compressor types so I believe this may be possible.
Thanks,
Jeff
Old Aug 5, 2009 | 09:57 AM
lsrx101's Avatar
lsrx101
Thanks,
Jeff
It could work, but you'll have to have new lines made up to mate the compressor to the old system.
That's an awful lot of work to change a compressor. I don't recall for sure but I "think" you would need to swap the timing cover from the newer motor for the accessories to bolt up. If so, there is no fuel pump mount. You could be opening up a big ol' can of worms.
A quality reman York compressor is about $250. A kit to convert to a Sanden compressor is about $350.
Old Aug 6, 2009 | 12:24 PM
redlightning93's Avatar
redlightning93
You will need a reverse rotation water pump, fan and clutch to go along with that serpentine set up as well
ole yeller 1978
Jun 27, 2025 07:31 PM
2002exPSD
Jan 14, 2014 06:39 PM
jeff gammon
Aug 4, 2009 11:56 PM
ole yeller 1978
Nov 5, 2007 11:43 AM
ole yeller 1978
Aug 26, 2007 09:02 AM
