WIDE 8 lug wheels,,dont know where to find them
Old 08-05-2009, 01:44 AM
71hightoy's Avatar
71hightoy
71hightoy is offline
im looking to upgrade the wheels and tires on my truck.. i would like to run some really wide 39.5 or 40"ground hawgs.... from what it looks like i either need 16.5 wheels but cant seem to find some nice looking wide wheels... or reallly any wide wheels other then white spoke.. i would prefer some nice weld wheels or mickey thompson's maybe... i looked on the internet but havent had much luck...
if at all possible i would like some DEAP dish wheels....as you can tell im looking for that wide stance with close to half the tire sticking out of the fender wells...
Old 08-05-2009, 02:00 AM
USArmyTaterness's Avatar
USArmyTaterness
USArmyTaterness is offline
how wide is wide and what is your bolt pattern
Old 08-05-2009, 02:04 AM
75F350's Avatar
75F350
75F350 is offline
Not sure where you are looking but there are several wheels that are 12 inches wide or wider.
You sure you want to run a 15.6" wheel? Why not a 16" or 17" wheel?
You will have far more wheel choices.
M/T does make a 16.5" wheel that is 12 inches wide, and 40" tires do stick out quite a bit.
You can even run a 15" wheel (my orange truck has them) and these require some offset that moves the tire and wheel further out than the police would like.
Old 08-05-2009, 02:13 AM
USArmyTaterness
Old 08-05-2009, 02:21 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
All 1953/96 F250's use 8 lug wheels with a 6.50" bolt circle.
1967/96 F350's are the same. 1953/66 F350's use 6 lug wheels with a 7.25" bolt circle.
Old 08-05-2009, 08:26 AM
Poison Oil Racing's Avatar
Poison Oil Racing
Poison Oil Racing is offline
go to your local tire store and look through their wheel catalog.
Old 08-05-2009, 12:08 PM
USArmyTaterness
thanx number well the ones i found will work for you then pal roo
Old 08-05-2009, 10:39 PM
71hightoy's Avatar
71hightoy
thanks every one for the help..
75f350 if I am not mistaken it looks like your running M/T classic II on your red truck... those are the exact wheels i wana run if possible.. are those 16.5's or just 16's on your red truck?
http://www.4wheelparts.com/Tires/Gro...&t_pn=SSTRV-40
thats the link to the tires i would like to run but 17 wide just sounds a little to much for the local yocals around here.. maybe i dont really care.. lol wont be on the road every day.. either way for these tires i would need 16.5 wheels.. is running a 12 wide wheel with 17 wide tires possible?? sorry im a nubie!
Old 08-06-2009, 12:17 AM
USArmyTaterness
I suppose if you found the right tire but I wouldnt do it I prefer my tires to more or less match wheel width
Old 08-06-2009, 12:45 AM
highboy1975's Avatar
highboy1975
highboy1975 is offline
i have eagle alloy 589s i think on my truck, look just like the mt classic2. 16x10, the widest they had. i rode all the way to wheeling to national tire and wheel and got talked out of 40inch hawgs and into 36 inch tsl radials, which i doubt the hawgs would have fit, and with the miles i do per year theyll last forever.
Old 08-06-2009, 05:19 AM
75F350's Avatar
75F350
75F350 is offline
Those are M/T Classic wheels, and yes they are 12 inches wide and the poor things are 16.5's. That tire is 18 inches wide, and I will never do that again!!!!!! Hear that? Never will I spend money on 16.5" wheels.
The width had nothing to do with that. IN this case, the major factor is the darn bead. The 16.5" wheel is a pile of crap.
Old 08-06-2009, 09:17 AM
fordrealdrive's Avatar
fordrealdrive
fordrealdrive is offline
16.5's are fine for street/mild trail use but they have no place on a hardcore wheelin rig. nothings worse than day of fun being cut short do to a unexpected tire dismount! as for tire width vs. wheel width, try to keep a 4''/6'' minimum difference between tire & wheel widths. most if not all tires have a approved rim size
Old 08-06-2009, 11:58 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
You've been doing this long enough that you should have known that YEARS ago. I'm a mere kid compared to you (mentality mainly ) and I could have told you that!
The 1st thing I do if I ever get 16.5s in the shop is set um outside for the scrap guy!
Old 08-06-2009, 12:06 PM
75F350's Avatar
75F350
75F350 is offline
Yes sir you are very correct. Unfortunately, when I was building these two trucks (the two red ones) I had intentions of keeping those old school turbine wheels. Remeber those?
Well I bought tires to fit them and then when I sold the 75 I had this set of tires that needed to go somewhere. Tough to sell them so I bought wheels for them. Pops needed wheels and he ended up with beadlocks. Blah, blah, blah, it was a poor judgement and a poor decision on my part.
Old 08-06-2009, 12:13 PM
ChaseTruck754
I forgot about that whole mess and keeping red as more of a "stock" looking truck.
Those turbines are definitely cool!
Speaking of keeping that "stock type look" - I totally forgot to tell you something about the fiberglass yesterday that might kill your plans for using it. Remind me next time we talk and I'll explain. It pretty much means you can't run your trim with it
Quick Reply: WIDE 8 lug wheels,,dont know where to find them
