i need a third pedal
Old Aug 4, 2009 | 10:47 PM
Jesse Zimmerman's Avatar
Jesse Zimmerman
ive had my automatic for a while now and the thing i miss the most about my other truck is the third pedal so i was wondering how hard it would be to do a transmition swap on a 93 f150, by the way would i be able to use the same transfer case or drive shafts
thanks jz
Old Aug 4, 2009 | 10:53 PM
Sycostang67's Avatar
Sycostang67
Very popular swap, if you do some searching you will find plenty of info. For starters though, you can retain your current t-case and shafts. Make sure you get a 4wd 5spd, as it's not easy to turn a 2wd transmission into a 4wd transmission.
Old Aug 5, 2009 | 01:09 AM
Alvin in AZ's Avatar
Alvin in AZ
x2 what Syco said. :)
I bought an F250 parts truck to do the same thing to a Bronco.
The pedal lever won't just add into the pedal assembly you have already. :/
(it's a Ford thing;)
The brake pedal pad was little so I swapped that to the F250's lever...
http://www.panix.com/~alvinj/file12/pedal.jpg
Are you wanting a transmission with a granny gear, so you can skip 1st? :)
If so, you'll have to get a ZF out of an F250 or F350.
That big ol' piece of crap is finally out of there! :)
Just did this today...
http://www.panix.com/~alvinj/file12/hoist3a.jpg (see my new pedals? :)
http://www.panix.com/~alvinj/file12/hoist4a.jpg
http://www.panix.com/~alvinj/file12/hoist5a.jpg
http://www.panix.com/~alvinj/file12/hoist6a.jpg
The plan is to weigh it tomorrow.
5 speed ZF weighs ~145 pounds.
T18 with a cast iron bell housing weighs ~182 pounds.
1356E weighs ~80 pounds.
Alvin in AZ
ps- I need a rubber pad for my new clutch pedal ;)
pps- Measured some stuff and put the cross member from the F250
into the Bronco and found holes in the frame, ready and waiting! :)
Old Aug 5, 2009 | 09:56 AM
alxsnmr's Avatar
alxsnmr
Reuse of the driveshafts depends on the trans you have in your truck currently. C-6s and AODs were 4" shorter than the M5OD and ZF5 while the E4OD was 3 inches longer than the 5spds. The 4spds (NP435 and T18) though use the same driveshafts as the C-6/AOD.
Old Aug 5, 2009 | 03:59 PM
Alvin in AZ
A drained E4OD weighs ~230 pounds.
Add 4 gallons of ATF and lines and 260 pounds isn't too far off.
5 speed ZF weighs ~145 pounds but add 55 pounds for the flywheel,
clutch disc, pressure plate and extra pedal... is about 200 pounds. :)
So not that much of a total difference really but working on them there
is, because the manual comes out in pieces it's easier to work with, IMO.
~150# T18 with a cast iron bell housing weighs ~182# +55# = ~237#.
Alvin in AZ
ps- squashed the hell out of one old bathroom scale today with that E4OD LOL :)
