Oil & Lubrication
transmision fluid
Old Feb 12, 2002 | 04:13 PM
red ranger's Avatar
red ranger
transmision fluid
i have a 92 ranger with the 5 speed mazda tranny and i was thinking of draining my regular fluid out and replacing synthetic... would synthetic benefit the life of my tansmision or just stick with what i have now... thanks
Old Feb 12, 2002 | 06:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
transmision fluid
Well you didn't say how many miles you got on it...
Why would you want to? I'm curious as to your reasoning behind it. I am a big fan of snythetics. SO I always recommend it but there are some circumstances where it soesn't warrant it. (i.e. like your trying to fix a problem by using it...)
Old Feb 12, 2002 | 11:40 PM
PAUL_2's Avatar
PAUL_2
transmision fluid
Some transmission synchronizers require a certain amount of friction to allow smooth shifts & a synthetic trans fluid can take away that friction . If its the M5OD you should be OK switching to a synthetic , Ive used it in mine since new with no problems . However , If you have any signs of leaks now they will only get worse switching to a synthetic .
Old Feb 13, 2002 | 02:23 PM
red ranger's Avatar
red ranger
transmision fluid
i just thought on changing to synthetic to improve the life on the tranny to run cooler etc. there is how ever no problem with my transmission its just i want to keep from having a break down and my truck has about 120 miles on the clock.....thanks MONSTA
Old Feb 13, 2002 | 02:28 PM
red ranger's Avatar
red ranger
transmision fluid
Thanks paul for the info...... im just new to synthetic and just wanted to know more about it .... thanks again
Old Feb 13, 2002 | 09:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
transmision fluid
