My 5.8l died, no warning and now no ignition
My 91 F250 was running like a champ and it suddenly died under acceleration. No sputter, the engine just died. All gauges and radio went dead. It will not tun over and nothing works when ignition turned on. It was like someone had turned the key to off while driving. The lights work, the horn works so the battery has power and I did take the alternator in to the parts store today and it tested fine.
Could it be the ignition switch? It seems odd that it would go after 45 minutes of driving and while driving. Any help would be appreciated.
Mark
Mark
doees your radio work? if so its prolly not your ignition switch. if thats the case thats a little confusing, if you didnt have power at all i would go for the fused link, or ig switch, but if you have power to the cab i guess it could be a loose wire somewhere. or if its real serious i suppose you could have broke something internaly(although you did bot say the engine locked up, so nevermind that)????????????/ im kinda confused
I replaced the ignition switch and it did not fix the problem. Turning the key does nothing. Again the horn, flashers and interior/exterior lights work (the same as they do when the ignition is off) but that is it. I arced the starter relay to see what would happen and the starter engaged. Any other thoughts??? Could it be the relay?
Mark
Mark
Sounds like fuse link "P" is open.
The Starter relay will not cause your problem.
Diagram:
http://i54.photobucket.com/albums/g9...ams/012-02.jpg
Diagram:
Fuse link "P" is in the diagram I posted a link to above. One end of fuse link "P" is bolted to the starter relay battery side and very close to the relay. Try stretching the fuse links there and if it stretches it is bad.
To replace just get a some 20 GA fuse link wire from an auto parts store, cut out the bad fuse link and splice in the new.
Fuse link "P" powers your Ignition switch.
