Cleaning coolant tank?
Old Aug 3, 2009 | 02:37 PM
strokersace's Avatar
strokersace
How the best way to clean out the coolant resevior? I've got an extra one that's pretty gunked up on the inside. So bad that you can't hardly tell where the coolant level is at.
Anything that can be done with a household mixture? Or some sort of special chemical?
Thanks!
Old Aug 3, 2009 | 03:21 PM
big poppa's Avatar
big poppa
Maybe a bleach and water mixture and let it sit..
Old Aug 3, 2009 | 03:36 PM
HH60FE's Avatar
HH60FE
OOps, don't even know how to edit.
Old Aug 3, 2009 | 03:39 PM
HH60FE's Avatar
HH60FE
Try muriatic acid. I had a 50/50 mix in a hard plastic bucket to clean an oil spot on the drive. Cleaned the heck out of the bucket, didn't touch the oil spot. Add acid to water, not water to acid. Try a 50/50 mix, get it in, slosh it around then get it out with a good clear water rinse. It hasn't eaten the bucket, been two months. Thought.
Old Aug 3, 2009 | 04:23 PM
orng1's Avatar
orng1
I use hand cleaner and some water then remove it and shake the hellk out of it. Keep doing that while keeping your hand over the hole. If it's really bad you can use that soapy water and a soft scrub brush and it comes off pretty easy.
Old Aug 3, 2009 | 06:45 PM
strokersace
Good point. That seems to clean other stuff...
Where in the heck can you get muriatic acid? Sounds kinda dangerous! But if it doesn't degrade the plastic, then it just might work.
A scrub brush will only get a little bit of it cause most of it is sectioned off.
IIRC, this was talked about a while back in a thread but I'm having trouble finding it in the search.
Old Aug 3, 2009 | 07:43 PM
sideshow's Avatar
sideshow
muriatic acid is what is in brick cleaner. i'd say most home improvement stores will have it. When I was in high school, we used to make acid bombs with it. Of course, a lot of things we did back then would probably classify us as a terrorist in today's society. Fact is, we actually did this kinda thing in chemistry, and our teacher told us about it. I'm sure I'm not the only one on this forum to do that kinda thing. A little muratic acid, some aluminum foil, and a plastic 20oz bottle. *****Disclaimer: DO NOT TRY THIS AT HOME KIDS!!!!!!*****
Old Aug 3, 2009 | 08:57 PM
big poppa's Avatar
big poppa
Give the bleach a try since it readily available and let it sit overnite, if its still gunked up try what the guys suggested..
Old Aug 3, 2009 | 10:57 PM
WA.Ranger's Avatar
WA.Ranger
Be careful of what you mix together, or you may wind up looking like you do in your avatar permanently!
Old Aug 3, 2009 | 11:10 PM
orng1's Avatar
orng1
Ususally the hand cleaner alone does the trick. Just have to do it a few times, warm water if it's real bad. Hasn't let me down yet. Hand cleaner like GOJO or something like you use in a garage.
Old Aug 3, 2009 | 11:17 PM
mueckster's Avatar
mueckster
A couple of people mentioned using vinegar, in a thread I read a while back. "Just give it a good douching", they said.
Old Aug 3, 2009 | 11:41 PM
7.3 Rocket's Avatar
7.3 Rocket
I've read of removing it and putting in a sand/water concoction then shaking it up real good and rinsing well. Or at least that's what the folks at PSN were talking about, but I don't quite trust them as much as FTE.
Old Aug 3, 2009 | 11:43 PM
orng1's Avatar
orng1
That's what the GOJO would do. It's got some grit and soap that loosens up the gunk.
Old Aug 4, 2009 | 09:08 AM
superduty4x4's Avatar
superduty4x4
BB's might work too. Pour them in and shake it up. I did that once to clean rust out of a metal dirt bike fuel tank.
Old Aug 4, 2009 | 09:20 AM
strokersace
Thanks guys! I've got some GoJo, Vinegar, and Bleach at home that I can try. The acid stuff kinda worries me. That is even if it's readily available anymore without a signed release from the president!
I'll work on it tonight.
