Door Ajar lite !
Old Aug 3, 2009 | 01:54 PM
RobertJohn's Avatar
RobertJohn
Door Ajar lite !
I've read the post, searched and done all I know to do the make that stupid Door Ajar lite go off.
I've sprayed WD 40, contact cleaner, carb. cleaner, use an air hose, everything I know to do but it's still on...
It looks like there are two trox bolts holding the rear door opener and this switch in place. This is an extended cab.
Has anyone ever had to take this open and clean the contacts or what ? It's no big deal but it's driving me insane and I don't have far to go to start with.
Thanks..
Old Aug 3, 2009 | 02:23 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Not meaning to sound like a smart Azz but did you clean/spray the latches on both doors. My buddy had the same problem and couldent get his door ajar go off till he remembered to spray the passenger side door latch.
Old Aug 3, 2009 | 02:59 PM
RobertJohn's Avatar
RobertJohn
Yep I've done both sides .........
Old Aug 3, 2009 | 04:31 PM
nissandoc's Avatar
nissandoc
Do you have any other problems going on such as no dome lights, key fob not working?
Old Aug 3, 2009 | 05:26 PM
RobertJohn's Avatar
RobertJohn
Nope no other problems except that dang Door Ajar lite..
I may just go with it for a while then tear into the latchs and see what happens then.
