Sponsored by: Real Truck
Left front STILL dragging!
Old Aug 3, 2009 | 12:17 PM
Shade's Avatar
Shade
Ok I've been fighting this thing for a while now and am at the end of my rope. The left front brake on my 03 is dragging and I've changed the caliper, the rubber line, the bearing assembly, and the fluid (twice); I've changed everything brake related on the left side except the rotor. What now? Any ideas here? I can jack the front up and spin the right tire and I get tired of counting how many times it turns but the left side I only get about 1.5 revolutions before it stops. I clean the wheels and in two days the left front is lightly covered in brake dust. Help! And btw yes, if I pry the pads away it spins fine so it is the brakes and nothing else that's dragging. Thanks for any help here it's really getting old.
Old Aug 3, 2009 | 12:47 PM
wizardsr's Avatar
wizardsr
This may sound like a dumb question, but did you lube the caliper slides well when you replaced the caliper? That would be the only thing other than the caliper (as far as I know anyway) that would cause the brakes on that side only to drag, other than a kinked brake line or something of that nature. A kinked or plugged brake line though probably wouldn't allow you to pry the pad back, and would cause a pull to the right when braking due to the restriction... If you've cleaned and lubed the slides real well, and they still dont slide freely, there may be some rust or something on them preventing them from moving freely. Hopefully that helps...
Old Aug 3, 2009 | 01:29 PM
Shade's Avatar
Shade
Yeah I cleaned up the slides with a wire brush and put neversieze on both sides when I replaced the caliper. I've done it at all four brakes now just in case.
Old Aug 3, 2009 | 02:52 PM
12ozd's Avatar
12ozd
If you jack up the left side front,and spin the tire,it will lock up with out even hitting the brakes?
Truck off?
Old Aug 3, 2009 | 03:07 PM
DetailerDave's Avatar
DetailerDave
Did you replace the springs that hold the pads apart? V shaped looking ones on the outer edge. And it sounds like the right side is looser than normal. Both sides of mine spin very little with the wheels off the ground, when spun by hand.
Old Aug 3, 2009 | 06:13 PM
Shade's Avatar
Shade
Truck off?
I pull it up to the concrete pad, shut it off, jack it up, and try to spin the wheel. Yes the truck is off and if I pry the brakes apart so it free spins then hit the brakes enough to stop the tire, let go of the brakes and spin it again, it drags. And, yeah, I changed the little v-springs when I last changed the pads. The truck rarely pulls ot one side or the other when stopping, I think when it does it's because of uneven road pulling on the tires.
Old Aug 3, 2009 | 06:40 PM
FortyFords's Avatar
FortyFords
Did you lube where the pad sits against the bracket?sometimes they get a burr worn in that area it will hold the pad from backing away.
How many miles on this truck ?
Are your rotors down to the wear marks yet ?
If the caliper has to push out to far sometimes the pads will get misaligned also.
Rich
Old Aug 3, 2009 | 06:56 PM
12ozd's Avatar
12ozd
Any chance the bracket that holds the pads is worn ?
Does the outer pad sit squarely on the bracket?
Old Aug 3, 2009 | 07:57 PM
Worn Out F150's Avatar
Worn Out F150
You might have a faulty residual pressure valve.
Old Aug 3, 2009 | 08:06 PM
Furian's Avatar
Furian
You Keep What You Kill
It sounds like it is ABS related...
Old Aug 3, 2009 | 10:17 PM
Shade's Avatar
Shade
Well the new caliper came with a new bracket so that's not worn out yet (didn't think to check that though)
Yes the outer pad seems to set pretty flat and square in the bracket.
Where are the wear marks on the rotors? It's got 229,000 miles.
What's a residual pressure valve and how do I check it?
If it's ABS related I guess I'll have to take it to a brake shop but none around here are very good.
Thanks for all the input guys, I'll look closer at that bracket tomorrow.
Old Aug 4, 2009 | 07:26 AM
Worn Out F150
It is a valve that keeps disc brakes under a slight amount of pressure (something like 5 PSI) to keep the brake pad close to the rotor and account for wear. Sometimes they will fail and hold too much pressure in and cause a caliper to drag. I have diagnosed the problem in the past by feeling how much force it took to turn the wheel, then opening my bleeder valve and seeing if the force required is significantly reduced.
