air cleaner box
Old Aug 2, 2009 | 06:09 PM
b.mewhiney7's Avatar
b.mewhiney7
air cleaner box
hey guys, quick one here, hopefully somebody's looked into this a bit:
i'm wondering about the inside of the air cleaner box, that dome-shaped inner section. i assume its purpose is mainly to tone down that intake "thunking" noise, however personally extra noise is not much of an issue for me (manifold -> 2.5" collector -> 5" downward-firing stack = freakin' loud).
does anyone know if the motor will breathe any easier without that dome-shaped piece? or does it serve airflow purposes as well?
thanks,
-bryan
Old Aug 2, 2009 | 07:43 PM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck
just cut it off flush with the top of lid and through away that is what most people have done
Old Aug 2, 2009 | 07:55 PM
LCAM-01XA's Avatar
LCAM-01XA
Find an airbox lid from an '86 or earlier truck with the 6.9 diesel, many of those didn't have the "soup bowl" you are looking to remove.
Old Aug 2, 2009 | 08:10 PM
FL-Mudd-Duck
they all had them. my 84,85,and 86 all had one on them
Old Aug 2, 2009 | 08:16 PM
LCAM-01XA's Avatar
LCAM-01XA
Well that's odd, my buddy's '86 ain't got one (wasn't cut off, just never installed), and in the junkyard I found quite a few like it too, which is exactly where I got my current lid with no soup bowl.
Old Aug 2, 2009 | 10:28 PM
b.mewhiney7
well, update time: i cut the soup bowl off!
noticeable difference: haven't a clue but i'd like to think it's more responsive! lol
Old Aug 2, 2009 | 11:06 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Some F series trucks did not have the soup bowl and most of the E series never had them.
But if the lid don't have a soup bowl, the bottom part of the air cleaner is necked down where it sits on the intake.
Creative sawing can increase that as well.
Old Aug 2, 2009 | 11:14 PM
LCAM-01XA's Avatar
LCAM-01XA
Dave is correct on the necked lower air box piece for trucks with no soup bowl. However, no creative sawing needed for that either - just find a lower piece off a 6.9 with a soup bowl, or any 7.3, they will all have the larger opening as they rely on the soup bowl to restrict airflow. Both me and my buddy are running 7.3 lowers with bowl-less 6.9 lids, no problems with airflow or water leaks.
Old Aug 3, 2009 | 04:25 PM
Mat J's Avatar
Mat J
are those banks power pack things worth a damn, my friend bought an idi with one already on it but to me just seems like a waste of money and i havnt seen them mentioned around ere.
Old Aug 3, 2009 | 09:41 PM
Dave Sponaugle
If that is the one with just a different air cleaner, probably little if any gain.
Power Pack Plus was the different air cleaner and a turbo if I remember right, they did make a difference.
Old Aug 3, 2009 | 11:06 PM
LCAM-01XA's Avatar
LCAM-01XA
Mat, I wouldn't bother wasting money on any aftermarket induction kit, unless it includes a forced-induction device (turbo) - you can make your own good-flowing intake for less than $20 worth of parts.
Old Aug 3, 2009 | 11:27 PM
dyoung14's Avatar
dyoung14
the power pack was for n/a motors and i believe they really do help, there is a guy on oil burners who has a banks power pack with exaust that came with it i beilieve, and has g code injectors and the turbo pump and he put out 143.9 hp and 261.3 ftlbs, no turbo!
Old Aug 5, 2009 | 07:17 PM
Mat J's Avatar
Mat J
yeah i already have a "ram air" set up, i didnt think the banks was worth to much over stock I also took out the soup bowl.
Old Aug 5, 2009 | 09:48 PM
johnboggs21's Avatar
johnboggs21
I thought they were rated for 185 HP and 360 ftlbs of torque stock??
Old Aug 5, 2009 | 09:59 PM
LCAM-01XA's Avatar
LCAM-01XA
That's at the crank tho, after all the losses in the driveline what you end up with at the rear wheels is quite different.
