I have heard they are hard to find. Up in the OBS Stroke forum they say to be sure and get that bracket when you get the axle as they are an obsolete part.
You might check out the classifieds, bad thing here is if someone has one, they probably also have the axle, so they are ngoing to want to get rid of it.
Rather common though, cut the U bolts, grab the axle, everything else falls to the ground.
Buy the axle and can not install it because you don't have all the parts to bolt it in.
anybody know where i could get the u bolt bracket for the bottom drivers side?
thanks for any sugsuggestions
What does it look like? Can you do a U-bolt flip? I don't know if the later model ones run up-side down or not like the 70's pickups do. I converted my '71 to run rear style U-bolts on the front. Pretty easy, and nothing hanging down to snag on stuff and looks much cleaner. I believe there is a pic in my album of what I am referring to.
