94 Ranger quarter panel rust
Back to regular programming!Plan to cover it when done with fender flares but want to stop the rusting in this one fender and fix it decently if possible. Other side (L/passenger) is fine - no rust. I have a qt of POR 15 black, qt of marine clean qt of metal ready and had a pint of my trucks blue made w/clearcoat.
Have access to a paint spray gun if/when needed. Anyone w/suggestions on what I will need other than what I listed for this project!?! I also have a drill type 4" sanding wheel for adhesive sand paper which I've used as you can see.
As you can see this spot is right where the wheel well in the bed meets the fender so getting in between to sand is next to if not impossible. I have a good eye for detail and the gumpshen to get it done just need someone to point me in the right direction.
