Oil & Lubrication
Oil consumption
Old Jun 24, 2002 | 01:03 PM
The Gunny's Avatar
The Gunny
Oil consumption
What quantity of oil consumption is considered normal with 2500-3000 miles between oil changes. I have a 01 SuperCrew 5.4L with 15000 miles on it. It's due for an oil change, but I had to put a quart of oil in it over the weekend. I've been keeping the change interval around 3000 miles, give or take a few hundred miles. My wife drives the truck daily because it has the car seat for the baby and her commute only puts about 3, yes 3 miles a day on it. We live and work on a military base which means that our commutes are very short. Therefore it doesn't get to normal op temp before it gets shut down. Could this cause more oil consumption that normal?
Glenn
Old Jun 24, 2002 | 09:56 PM
Paarrothead's Avatar
Paarrothead
Oil consumption
I drive a 2000 F-150 5.4 and I've noticed that how much oil it uses depends a lot on what I put in there. In the summer when it's hot here in Colorado (90+), if I use the Ford recommended Motorcraft 5W-20, it'll use a quart about every 1,200 miles. If I use Mobil 1 10W-30, it'll use a quart in about double that, about every 2,500 miles.
I've got the Motorcraft in there now (because it was on sale), but I'm switching back to the heavier grade Mobil next time.
Man, I don't feel right about using 5W-20 water, regardless of what Ford recommends.
Anyway, it seems fairly normal for some of the Ford modular engines to use what seems to be a lot of oil, so I don't think you really have a problem.
My '96 F-250 460 with 120,000 miles uses less than a quart of 10W-30 every 3,000 miles.
Go figure.
It's a Ford.
Old Jun 25, 2002 | 12:13 PM
Superbru's Avatar
Superbru
Oil consumption
Oil consumption will vary between engines, even of the same type. My 5.4 uses virtually no oil between changes. (3000 mi.)My 302 in my 85 Mustang Gt will use a quart of oil every 2500. All with about the same driving habits.
The dealer will probably tell you a quart every 1000 miles is normal, although most new engines will use less than a quart between changes. Anyway, I think a quart of oil every 3000 miles is OK, especially the way you are driving the vehicle.
Just my .02.
Bru
2002 F150 Super Crew
Black 4X4 Lariat
5.4 Engine Ford Chrome Bars
1979 Bronco 351M 75K orig.
Old Jun 26, 2002 | 10:30 AM
jim henderson's Avatar
jim henderson
Oil consumption
