1978 - 1996 Big Bronco
grinding noise
Old Jul 31, 2009 | 12:09 PM
fordbroncodave's Avatar
fordbroncodave
grinding noise
when i am on a hill, facing down, and i try to drive the truck in reverse up the hill, it makes a loud *** grinding noise just as i hit the gas a little. its really loud because the windows were up and the stereo was on
it occasionally makes the same grinding noise when i am driving forward on a bumpy road.
my initial thoughts were the tie rod ends were lazy and pushing the brake shields into the rotors but when i was on the hill, that was not true because i wasn't moving when it made that loud grinding noise.
does it have anything to do with the motor twisting a little when load is applied to it? i was jumping on the front bumper with the engine on and i couldn't get it to grind.
1989 bronco fulsize xlt 5.0 AOD trans, borg warner case, 8.8 rear and 44 front 31' tires
Old Jul 31, 2009 | 03:55 PM
b4hntn's Avatar
b4hntn
Have you looked to see if the fan is hitting the shroud?
Old Jul 31, 2009 | 05:52 PM
fordbroncodave
its not that noise. i spin freely with a little resistance.
it sounds like metal on metal so similar to the noise of the brake shield against a turning rotor.
i am afraid what ever this noise is, is creating sparks when it grinds. not a good situation.
i have been under it and shook anything i can get to move loose and nothing is grinding.
could it be the starter bendix not retracting all the way? could the flywheel be loose?
fordbroncodave
