Question about my vin
Old Jul 31, 2009 | 08:20 AM
PawPaw's '66's Avatar
PawPaw's '66
I have a 1966 f100 twin I beam with a 352 v8 and my vin starts out like F10YL and it is my understanding that the first letter after the F10 is the engine code however mine is a Y which is not in the engine codes for a 1966 but is for a 1967. Am I missing something?
Old Jul 31, 2009 | 08:27 AM
Fordtillidie's Avatar
Fordtillidie
Quite honestly im not entirely sure why that is but if you go to Google you can look up vin decoders and they should point you in the right direction
Old Jul 31, 2009 | 09:51 AM
Little O's Avatar
Little O
PawPaw, Ironically, I just decoded my entire VIN yesterday on a 1966 F100 with a 352cid. The F10 = F100 with 2-wheel drive. The Y = 352 cid 8-cylinder (I don't why some lists for '66 models don't include the Y). The next should be a letter, say like "N" and then a string of numbers. The letter is the code for the assembly plant. In my case, N is for Norfolk, VA. The string of numbers is the consecutive unit number. If you post a picture of the VIN tag, I'll decode the whole thing for you. Little O
Old Jul 31, 2009 | 10:12 AM
PawPaw's '66
Thanks O. I used the decoder on this site. I was just confused about the Y because from what I've seen the 66 did not use the Y as an engine code option but did in 67. By the way, my truck is a Michigan truck.
Old Jul 31, 2009 | 03:12 PM
camperspecial65's Avatar
camperspecial65
Y is the 1966 code for the 352 engine...L is Michigan Truck...where it was assembled...dont see many of those around here in my experience..
- cs65
Old Jul 31, 2009 | 03:22 PM
PawPaw's '66
The engine codes that I had seen for the 1966 were B for the 300ci and D for the 352ci and Y was for the 352ci in the 1967.
Old Jul 31, 2009 | 03:30 PM
camperspecial65
D is the 352...for 1965 trucks...I got one...Y is a 352 in a 1966 truck...I had one...
additionally, I have the Ford Truck Master Parts catalog which has all of the codes for these kind of things...
- cs65
Old Jul 31, 2009 | 03:34 PM
PawPaw's '66
This is what I was looking at.
Old Jul 31, 2009 | 03:36 PM
camperspecial65
k...they are still wrong though about the engine code for 1966 F series 352 though....nobody is perfect though...
- cs65
Old Jul 31, 2009 | 03:42 PM
PawPaw's '66
Well now I know why I've been scratching my head about the VIN on my truck. I have just recently got this truck from my grandpa to start restoring it and found that info on the engine codes and didn't understand why it wasn't a D. Learn something new everyday.
