95 ford explorer v6 4.0 auto so about 2 weeks ago my engine started having a ruff idle and since then has gotten much worse when I give it gas from a stopped position like a stop light it will start stalling or will stall if it dosnt stall it will shake bad and move very slow the air coming out of the exhaust is putting out the truck has no engine codes to give me a idea of whats going on so far ive tried:
-Coil pack
-MaF sensor
-Fuel injector cleaner
-checked the pressure before and after the cat to make sure it wasnt clogged
-Checked vacuum hose lines for pressure loss
Plugs and Wires where replaced about 8000 miles ago
anyone have any idea where I should look next ?
Thanks -Jeff
I was thinking the same thing when reading that, my first thought was the egr valve or the egr tube its self. Have you made sure the air filter is clean? Because a bad air filter will cause less air flow of course and will cause the suction coming from the throttle body to scrunch the intake hose and cause throttle trouble.
Took the egr out today tested it with a hand vacuum opens and shuts fine sprayed the inside with carb cleaner to clean it out but the weather turned on me so I wont be able to put it back in till tommrow to see if it made a diffrence
