1978 - 1996 Big Bronco
5.8 bronco wont start
Old Jul 30, 2009 | 05:23 PM
Rackpatrol's Avatar
Rackpatrol
My son started his 1995 BRONCO and the check engine light came on. So he turned it off and tried to restart it. Now it has fuel but no spark at the distrbuter. I checked the coil and compared ohm's with my 1992 that is still working and the were the same. My code reader says 121 and 565, PLEASE HELP.
THANKS
Old Jul 30, 2009 | 06:18 PM
Mustang6147's Avatar
Mustang6147
No spark at the ditributer... I am guessing that , that meens coil wire correct? Is the power going to the coil when key is on?
Does that distributer have that big plug on the side, , cuz that is what it sounds like... I think it is a mudule. But I would trace power back as far as you can
Old Jul 30, 2009 | 06:38 PM
masseysbronco's Avatar
masseysbronco
121 = Closed throttle TPS voltage higher or lower than expected.
Sounds like a bad TPS, its at the bottom of the TB which will need to be removed.
565 = Canister purge circuit failure
I think this relates to the little device thats mounted beside the EGR. It has a vaccum line that connects to the left side of the TB and the other side goes to the charcoal canister which is to the right and below the battery on top of the framerail.
Old Jul 30, 2009 | 07:10 PM
g_k50's Avatar
g_k50
Do you have spark at the spark plug? Will the engine start with starter fluid in the air intake box?
No spark, look at distributor and ignition control module.
Starts with starter fluid, look to fuel pressure, fuel pump, fuel regulator, fuel filter.
Old Jul 30, 2009 | 08:11 PM
Mustang6147
While I agree with your G-K I dont like the starting fluidthing... I would reccomend gass sprayed in the air intake the turn it over. Starting fluid is bad stuff.
If it is the tps just unplug it, It will run just at a Higher RPM. If that is it, Problem solved.
I kind think it is a module though from his description.. It will be intresting to see
Old Jul 30, 2009 | 10:10 PM
g_k50's Avatar
g_k50
The starting fluid creates a problem because it washes the oil off the cylinder walls, I think. So I wouldn't recommend it other than a troubleshooting method and it's already available ready to go, while the gas sprayed in the air intake would have to be rigged up.
I think that the reason starting fluid is used is because it vaporizes easier than gas does. The point is that it's a troubleshooting step to narrow down the complexity modern engines.
Old Jul 31, 2009 | 04:52 PM
Rackpatrol's Avatar
Rackpatrol
I unpluged the tps and it still did not try to start. The coil had voltage when key was turned to on position. I am leaning toward the distributor but i was wanting as much advice as i could get.
Thanks to all.
Old Jul 31, 2009 | 07:55 PM
greystreak92's Avatar
greystreak92
Did your son mention anything about the way the engine was running just before he shut it down? I only ask because it could shed a little more light on this issue.
I am assuming it cranks but won't turn over. The codes you mentioned shouldn't be cause to keep the truck from starting. And since you can't get it running, the KOER test is out of the question. Are you certain you are getting spark from the coil? Never hurts to shove a screwdriver into the coil wire and check for it while someone cranks the engine for you. (Be careful... hold the screwdriver BY THE HANDLE about 1/4" from any ground source). If you have spark there, do the same test with one of the plug wires. this will tell you if the PIP sensor, distributor wiring and TFI module are working.
Old Aug 1, 2009 | 04:52 PM
g_k50's Avatar
g_k50
The Powertrain Control Module (PCM) sends the spark dependent upon the signal from the distributor.
Troubleshooting this one is a pain in the A. The distributor in my 1990 Bronco went out, but it was a gradual thing, it stopped working and then it would start working later, so I was thinking heat issues, finally it stopped all together with no spark, I changed the coil and still no spark, so then I tried Ignition Control Module (ICM) still no go, (that one was a pain in the A itself, freak size bolt head and deep)
I ended up rebuilding the distributor complete, I think the stator was the problem.
Try a rebuilt distributor, would be my suggestion.
and check the cooling system.
Old Aug 1, 2009 | 06:58 PM
greystreak92
PIP (Profile Ignition Pickup) sensor is probably the single most difficult (or at least contrived) sensor to troubleshoot. From the sound of things, this could well be the issue here. It is quicker to just replace it however it is not an inexpensive component. The PIP sensor is the ONLY failure point internal to the distributor short of an obviously damaged rotor or cap. No point in replacing the entire distributor if the PIP sensor can be replaced to solve the problem. The trigger for the PIP sensor is the excitor ring that is bolted immediately below the rotor. If you remove this ring you can see a series of "teeth". If these teeth get damaged or bent, they can cause physical damage to the PIP sensor. If you can eliminate other potential causes for the problem, I know the process for troubleshooting the PIP sensor. I can certainly post it or send it to you.
Old Aug 1, 2009 | 10:34 PM
Rackpatrol's Avatar
Rackpatrol
Yes I would like to see the trouble shooting process. I have tried swapping the coil and the TFI from another truck with no luck. so I have a feeling the problem is at the distributer THANK YOU FOR YOUR HELP
Old Aug 2, 2009 | 02:57 AM
johnboy427's Avatar
johnboy427
What are your cap and rotor like? My brother drove his 95 5.8L till one day it wouldn't start. 189,000 miles on a cap and rotor and they get that bad. After wards he said it never ran so good. Check to see if you are getting spark at the coil and it just can't make it out of the distributor that how we pegged his problem.
-Johnboy
Old Aug 2, 2009 | 07:20 AM
b4hntn's Avatar
b4hntn
While you are at it, I suggest checking the grounds on the fender by the battery. The nuts may be tight, but the stud may be turning in the fender creating a bad or intermittent ground. One or both of the two small wires go to the ignition system. Mine was damaged when the battery cables were replaced and the pigtail ground wire over to the fender ground was reconnected.
Old Aug 2, 2009 | 12:59 PM
Rackpatrol's Avatar
Rackpatrol
no fire at coil. and grounds look good I took them off and cleaned them, but nothing changed, THANKS AGAIN
PS: Keep trying
Old Aug 2, 2009 | 02:00 PM
Kemicalburns's Avatar
Kemicalburns
when you crank the motor does the dizzy turn?
Gunnerboy
15
Jun 15, 2017 09:23 PM
Dads79
May 18, 2017 09:59 PM
crazed87bronco
30
Jun 7, 2013 05:37 AM
fordsaintnevergonnad
May 27, 2011 04:00 PM
huntsmuleys
13
Dec 2, 2010 01:13 PM
