Ball Joints
Old Jul 31, 2009 | 02:23 PM
quaddriver's Avatar
quaddriver
keep in mind, your assembly proceedure for the hub nut will be VASTLY different depending if you havethe ratcheting type nut, or the pinned locator and nut.
perform the wrong method on the part and it will be destroyed.
Old Jul 31, 2009 | 02:35 PM
Volvo92906's Avatar
Volvo92906
I can find that out as soon as I get it apart... I dont have the socket for the hub nut.. Is it possible to use a pair of channel locks on this? I never had it apart but im guessing there might be a 'tunnel' because of the locking hub. Any info.
Old Jul 31, 2009 | 03:02 PM
quaddriver's Avatar
quaddriver
no, if anything, a long nose set of needle nose might work, but if you have the pinned nut - they will never develop the torque needed
Old Aug 1, 2009 | 12:52 AM
Dirt racer's Avatar
Dirt racer
Before I got the correct socket I had a pipe with the end cut like the socket and it had a hole drilled through it to put a big screw driver. It worked ok. But you would need to have a nut to make it correctly. The socket works the best though.
Old Aug 1, 2009 | 05:42 AM
Volvo92906's Avatar
Volvo92906
Thank you all for the information. Im heading out now. I didnt get a socket but if I cant manage something I called up a buddy at the truck shop I used to work in. HD trucks have the same special hub nuts so I can borrow one from there. Hopefully everything comes apart in decent time. Thanks again!
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
