vin decode
Old Jul 30, 2009 | 10:55 AM
jwh f-100's Avatar
jwh f-100
vin decode
I haven't had luck finding a decoder.. Please & Thanks...
E105H100935
Old Jul 31, 2009 | 05:47 PM
66gpw's Avatar
66gpw
I wil give it a try.
E10 --- Pick up
T -----170 CId 6cyl motor. (I think you did a typo here)
H -----Lorain Assembly Plant
100935 -- Sequence number. It says manufactured in Oct. 1961
I said I will try. But in 61 the trucks came with a 144 engine. The 170 engine came later. So the truck must be a 62. Let me know if I'm right.
THANKS
Old Aug 3, 2009 | 12:36 PM
jwh f-100's Avatar
jwh f-100
Thanks!!!!!
I wish I knew if you are correct..
That vin is on a registration I got with a F100..
Old Aug 3, 2009 | 01:56 PM
66gpw's Avatar
66gpw
The E10 of the vin code means a Econoline Pick up. Not a F100 truck. Someone may of changed the serial number on your truck or the registration.
If you have an actuall Econoline van or truck a secondary location of the serial number is on the brackets that cross the corner at the back of the vehicle. This bracket is in front of the tailights. There should be a serial number stamped into the metal. If it is an actaull F100 I do not know of a secondary number.
Old Aug 5, 2009 | 03:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E10SH100935.
This is a 1961 Econoline assembled in October 1960, not October 1961.
1961 serial number range: 100,001 thru 205,000 / October 1960 serial number range: 100,001 thru 109,999.
The VIN's 4th digit is the letter S, not the numeral 5.
S = 144 1V.
Old Aug 5, 2009 | 05:44 AM
66gpw's Avatar
66gpw
That makes more sense. The s code than five. I thought maybe he hit the 5 above the letter T on the board.
Stand corrected about the year. Got a year ahead of myself. Thanks Number.
Now the question is does he have a F100 or an Econoline.
jniolon
Sep 1, 2018 10:10 AM
Nattycakes
Mar 29, 2017 02:10 PM
cmongfe
Large Truck
Apr 15, 2015 01:19 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 21, 2014 06:00 PM
Mulletwagon
1978 - 1996 Big Bronco
Dec 6, 1999 01:12 AM
