2nd Tow and now I'm IMPRESSED
#63
well I'm the first to believe that your truck can stay in 5th gear when towing at any speed above 50 mph. This is due to one of my past 7.3's with a five speed, 4.10 and tuner would never need to be shifted out of 5th once rolling with loads up to 12k. I also go out west hunting with friends 4 quads, toy hauler, and rest of gear in a 04 5.9 auto-trans that has been worked that doesn't even shift out of OD while towing.
#64
I believe that you can pull without having to downshift! I used to tow with a 7.3 5-speed and anything overhe tra 50 mph with loads up to 12k. I go out west hunting with friends 4 quads and toyhauler using a 03 5.9 auto and it stay locked up in OD pulling 13k tranny does have a suncoast torque converter and banks 6 gun. The point is diesels create great torque down low and if you never owned one you wouldn't understand the difference.
#65
the extra cost will be there if youre talking about the same year, same condition, etc. i just think its funny hearing someone that paid 40k for a truck complaining about the higher cost of anything. for the extra amount he spent buying new rather than used i can buy my diesel truck and a lifetime supply of oil, filters and tires and still have money left over.
actually, for what ive been arguing, it does matter which one tows better. i didnt join the argument until several 5.4 owners were saying the 5.4 would outpull a 460 and 7.3, two trucks ive done quite a bit of towing with. i have no problem with them saying their truck will get the job done, they like it better, its fancier, they like all the gadgets, they prefer it to a 250 or a diesel, etc. but dont tell me that a 1/2 ton gas truck is a better tow vehicle than a 3/4 ton diesel. as far as structural and powertrain goes, the two arent even in the same sport, much the same ballpark. all the other frilly things dont do a thing when it comes to performance or durability.
I know when you joined the argument. Remember I said that I've been following this forum for the past couple of months and I know what's been said by which side. I'm not sticking up for the misinformed owners that think their 5.4L is god. You were totally right to come in then and tell them the facts. What I'm saying is that argument is long gone and dead, and you are the only one bringing it up as if it's justification for you to continue putting other trucks down. No one in this thread is still saying that their 5.4L will pull circles around older diesels or the 460. All that's been said in this thread is that they like their new F150 because of how nice it is, how quiet it is, how they like it over a bigger truck for their needs. There's nothing wrong with that! All the cool gadgets may not help performance or durability, but they don't hurt it much either. So why are you persisting? Even if someone out there still did think their truck would outpull yours, it's obvious by now that they aren't going to change their mind. So why don't you be the bigger man and let it go?
#66
lol..wharrgarbling
#67
#68
#69
Come visit the V10 forum sometime.
If you compare the 5.4 and the V10 doing the SAME TOWING JOB, the V10 can actually get BETTER mileage because it's not working as hard.
Unloaded highway driving can be around 1MPG less for the V10, but again, towing, it can actually get better mileage than the 5.4
#70
i admit i did choose to gloat a little excessively when peter gave us his results. i didnt like being told i was wrong and that i should leave the forum and never come back because i gave the results of peters test BEFORE he even drove the truck. but consider the argument dead now.
#71
5k lbs is well within the 5.4's limits, assuming youre not climbing huge grades on a regular basis. but dont expect to do much towing in OD, even on small hills. if i was looking at buying a new truck then i would go with the v10 100% of the time. its only a few hundred dollars more, the mpg's unloaded are too close to make a difference and the performance and mpg's when loaded arent even in the same ballpark.
#72
If 5-6000 lbs are going to be the extent of your towing, a properly equipped F150 would do just fine and get much better fuel mileage than the same engine in a SD F250. By properly equipped, I mean 5.4L, 3.73 gears, max payload springs and E rated tires. I have 3.55 gears and P-Metric tires and my 06 pulls my 7000 lb enclosed car hauler great. I added an Add-A-Leaf the the rear springs to get the same ride height that my 05 SD had and I am surprised at how stable the truck is pulling the trailer. The only thing I need to do now is get the E rated tires for it. I know I can't run 75 mph down the highway as easily as the the Power Stroke did and it won't climb long grades with the ease of the diesel, but it does good enough for the times I do tow. And I get much better mileage than if I would have gotten a SD V-10 or 5.4L.
#73
Be careful
#74
I had the 3.55 as well hauled about the same load as you are and my rear end trashed out. I may have been making longer and more tows that you though. I support the 5.4L 3.73 comment though. That should be fine unless your doing a lot of mountain to heavy hill towing then the larger trucks are the only way to go.
#75
Just what I said
Like you say thats your experience. Mine was different. It was not really trashed I installed a kit for around 300$. I dont think it liked the elk hunt. Like I did.
