electrical connector help
Old Jul 29, 2009 | 01:22 PM
nbtone's Avatar
nbtone
I have a 1993 non turbo diesel F-350 w/automatic transmission. The electrical connectors under the hood on the firewall have a 10 mm bolt holding them. I want to take these connectors apart to spray some contact cleaner in them, but I can't figure out how to do it. Any help would be appreciated.
Old Jul 29, 2009 | 01:57 PM
timbersteel's Avatar
timbersteel
I'm not an expert, but I think that is the same size bolt as my wiring harness under the driver side firewall. It was a PITA to get a socket and sorts in there to remove it. I just worked at it till it freed up. Be sure that you have the Battery disconnected before you disconnect them.
