Weird front end sound.
Old Jul 28, 2009 | 05:31 PM
Bowie's Avatar
Bowie
So I have been reading post on here that talk about needing new hubs and lubricating front bearings (or something like that.) It got me thinking. I have a weird sound in the front end of my truck. I thought at first it might be the front drive line spinning, but it moves free at a stand still and I had my wife drive while I looked under, I could see that it was not spinning. So I am not sure what the sound is. The sound is not loud and it is not at all speeds. I wondered if anyone has experienced this or can explain what a front end going out would sound like. I only have 55,000 miles on her.
Thanks
Old Jul 28, 2009 | 06:59 PM
cgl's Avatar
cgl
Can you possibly explain the sound? Can it be heard with the windows up/down? Any details will help. I have some ideas but don't want to steer you the wrong direction, if it can be helped...
Old Jul 28, 2009 | 07:00 PM
jwhitetail's Avatar
jwhitetail
At that low miles it should not be anything wrong, are you hearing tire noise? some times tires make funny noises.
Old Jul 29, 2009 | 08:48 AM
tbone heller's Avatar
tbone heller
Pull the front hub locks off & drive it . If the noise is gone, one of your hub locks is bad. Re-install the locks one at a time to determine which one is bad. This may not be the problem, but it will eliminate a lot of stuff that could be bad.
Old Jul 29, 2009 | 09:01 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Tire noise is common, especially if you've got big tires. If a tire is a little low on air, tires need rotating, many possibilities.
Old Jul 29, 2009 | 12:03 PM
Bowie's Avatar
Bowie
It could be a tire noise, just sounds like gear noise more to me. I do feel a slight vibration inside the truck at certain speeds then it goes away. does that help?
Old Jul 30, 2009 | 12:07 PM
cgl's Avatar
cgl
I have a clicking noise that I can hear whenever my suspension moves. I've narrowed it down to the drivers side sway bar link. I can reach in there and move it and create the noise...
