smoking ex
Old Jul 27, 2009 | 10:18 PM
chawkjr's Avatar
chawkjr
smoking ex
hey all, everytime I give my 03 6.0 the gas black smoke keeps comming out. when I noticed it ,I started letting off and then giving it gas to watch what its doing it happens all the time recently, also I have a # 7 slightly clogged injecter or the wiring to it is messed because at 45 mph. it it runs a liitle irratic until 55mph then it smooths out or if I let off the gas and reapply to downshift it goes away until it shifts back to hi gear at 45mph then it comes back.
I am more concerned about the black smoke more than anything your help is wanted thanks
Old Jul 27, 2009 | 10:31 PM
william_04_x's Avatar
william_04_x
You probably have a leaking injector and need to get it checked out ASAP.. Check your oil to make sure the level isn't rising because of fuel getting into the crankcase.. This won't fix itself and can get much worse very quickly..
I had this happen on the way home from a vacation a couple of years ago.. I shut it off 6 miles from home when I couldn't stand the sounds it was making anymore.. A cylinder was on the verge of hydrolocking.. Got the injector replaced and no related problems since..
Old Jul 29, 2009 | 06:23 PM
chawkjr's Avatar
chawkjr
I drove it home to ca. from texas this way the truck run great except for what I explained above and changed the oil when I got back no fuel in the oil
Old Aug 7, 2009 | 12:37 AM
GreenExcursion's Avatar
GreenExcursion
Is this a common cause of excess smoke?
Old Aug 7, 2009 | 06:38 AM
jackassjeeper97's Avatar
jackassjeeper97
could be a stuck injector.,They will dump fuel into the system constantly. Have you noticed any fuel economy difference?
